Question about Epson 9-pin Impact Dot Printer
How to add epson dotmatrix 9 pin LSP 100 to the
How to add epson dotmatrix 9 pin LSP 100 to the system having VISTA O.S. abdulmlone@gmail .com
  • 59 Answers
Dear, pl install start/control panel/printer and faxes/add printer select epson select epson 9 pin compitebale
Posted on Mar 02, 2009
How should I open my WeP Dotmatrix printer top panel to change the board
Sir/Madam
You Need To Go Below URL Link and download Some file To Fix your Epson Printer Problem,I Hope after Download file and follow instruction metion on the URL Link Site You able To Fix Your Epson Printer problem :
SOLUTION
  1. Download the attached file(s). You will probably just need the 24-pin PPD, but I have also included the 9-pin PPD (which I haven't tested) just in case.
  2. Browse to the CUPS web interface at http: // localhost:631
    NOTE: The printer installer system from the GUI will NOT work. It will throw an error and promptly fail
  3. Create the printer listing using the CUPS web interface, and when it asks for a PPD, point it at the one you just downloaded
  4. PROFIT!!
I hope this helps someone, ANYONE who has been in the same straits I have been.
So man your chips, and may The Source be with you!
Thread Working with WIPRO WeP and Epson dot matrix printers
Or
You Still having Brother Printer Problem then Follow Us On:
Epson Printer Support
Jul 12, 2011 | Epson Office Equipment & Supplies
Tip
EPSON Impact Printers on a Mac
Connection Type : USB or TCP/IP
Driver : EPSON 9-pin or 24-pin Series 1.3
(resident CUPS / PPD driver - provided by Apple)
(no official EPSON driver)
>USB direct connection - check System Profiler-> under USB connection
>Got to Print & Fax and add the printer using the above driver
>TCP/IP connection - LAN set-up for printer configuration
>download EPSONNet Config Utility from http://support.epson.com
>run app and it will locate the printer regardless of IP address
>config to taste - default user/pass (it's blank, just hit OK button)
*the EPSONNet Config Utility is also available for Windows
(it's a neat utility)
on Jun 15, 2008 | Epson DFX-9000 Matrix Printer
Ik kan soms wegpagina niet openen en krijg als fout : "LSP (Layered service provider) werkt niet juist. Hoe is dat op te lossen? Dank bij voorbaat
Herstellen naar een vroeg stadium en het scannen en verwijderen van virussen met een goede virusscanner en werk vervolgens de LSP uit Micrososft.com
Jun 29, 2011 | Microsoft Windows Vista Home Premium with...
I have lost my panasonic kx-p1150 dotmatrix printer driver cd
Hi
No need to download the driver your driver with windwos, please click the add printer and find the panasonic and right side u get your KX-P1150 model no.
Good Luck and Enjoy...
May 11, 2011 | Panasonic KX-P1150 Matrix Printer
Unlock code for lg lsp 350r
Hi
Just get the lg lsp 350r unlock code through the LG UNLOCK CODE website. They will provide you with the IMEI unlock code. Just type the IMEI unlock code on your phone and your phone is 100% SIM lock free. Their codes are 100% safe and accurate.
Jan 21, 2011 | Cell Phones
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
I Want a driver for my WIPRO LQ 1050 PLUS DX DOTMATRIX PRINTER AND MY OPERATING SYSTEM IS WINDOWS VISTA. please guide me how this will work out... I have a usb cable connected to my laptop.. Nikul
If you have the CD which you might have received with the printer go ahead an install the driver software using the CD.
If you don't have the driver CD to install the Printer Driver go to this website to download the driver for the same.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Downloads&oid=14323&category=Products
If you are install the printer using the CD, try not to plug in the usb cable in the begning/ the driver software will ask you to connect the usb cable so try to connect it at that time.
Aug 14, 2010 | Epson LQ-1050 Matrix Printer
M$ Internet Exploder 7 shuts down: Assert in LSP error popup
Your google desktop add-on is causing the problem. Try to start IE7 without add-ons. Right Click your IE7 Icon and start without add-ons, or go:
Start | All Programs | Accessories | System Tools | Internet
Explorer (No Add-ons)
Or type in this command at Start > Run
iexplore.exe -extoff
This will start IE7 without all the toolbars or add-ons that you can download or add to your Internet Explorer.
Go to Add/Remove Programs in Control Panel and uninstall the Google Toolbars/Desktop programs then try to start IE7 normally again.
Feb 18, 2009 | Computers & Internet
Tvse nova 130 printer drivers needed --cannot print from vista
No external drivers are required for this. select from your windows driver list epson lsp 100 will match exactly with it.
Feb 09, 2009 | 2005 TVS Star
Epson 9-pin Impact Dot Printer Logo
158 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
