Question about Pioneer DEH-P7900BT CD Player
Twice my Pioneed DEH-P7900BT has just stopped working. Keyboard went dark and the unit shut off. I pressed the button to open the face place and it opened and is stuck that way. It also didn't eject my CD that is in there. Any suggestions? Thanks.
  • els622 Mar 02, 2009
    Thanks. I talked to the people that fixed it last time and they told me they had to replace the entire amp unit, but did not say if they knew the cause.
    Novelist:
  • 149 Answers
This sounds like a wiring problem. Double check all of you connections. If the Connections look good then I would check the connections inside the radio. Check the power wire mostly. The wire could have a bad solder joint inside the radio itself.
Posted on Mar 02, 2009
I have the Pioneer DEH-p7900bt and when i hook it up in my car the everything works except the screen, only the top third or so of the display screen lights up. but all everything else lights up. i dont...
I say it is the screen or face if you well mine did the same thing and it is cheaper to find one on ebay than to repair it. I checked one place out and they wanted like 60.00 well good luck and take care
Mar 18, 2011 | Pioneer DEH-P7900BT CD Player
I need to know how to pair my phone to my c.d player
Turn the bluetooth on in ur phone.
Use MULTI-CONTROL to select
Connection open in the function menu.
Press MULTI-CONTROL to open the connection.
Always waiting is displayed. This unit is now
on standby for connection from Bluetooth
device(ur phone).
If your Bluetooth is set ready for
Bluetooth wireless connection, connection to
this unit will be automatically established.
Jul 04, 2010 | Pioneer DEH-P7900BT CD Player
I have a DEH-P7900BT. It was working very well for the last one year. But last week onwards I am facing a strange issue. The audio from the system go blank (mute) for few seconds and then come back. This...
I would check both of the power wires for the unit. There is a yellow one and a red one. The yellow one always has power regardless of the position of the ignition switch. The red one only gets power when the ignition switch is in the on position. Also does this only happen when the vehicle is in motion or does it happen just sitting and listening to the stereo? It also could possibly be the ground wire not getting a good connection. Make sure the ground wire is tightly connected to something that is metal. Good luck.
Jul 18, 2009 | Pioneer DEH-P7900BT CD Player
My radio is not responding.
Put the right bottom corner of the face to head unit,bring the left bottom corner to headunit and press gently.
Apr 08, 2009 | Pioneer DEH-P6800MP CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
How to I change the clock setting for a pioneer car radio deh-2750mp
Turn on the car so the stereo is playing.
Press, and hold for a few seconds the 'SRC' button [Bottom left side of the unit face]. This will turn the radio OFF. The clock may or may not be visable at this time. If it is visable, press the 'CLK' button [top left side of the unit face] to make the clock turn OFF.
The screen should now be blank and dark.
Press the 'AUDIO' button [Top Right side of the unit face] and hold for a few seconds. This will open the functions menu. The clock setting should be first in the list. Use the arrow keys to set time and toggle between the hour and minutes.
By sequentially pressing the 'AUDIO' button, you can also set the tuning scans from 100 to 50 kHz in FM or from some other scans in AM, but there is really no need to do this.
Mar 21, 2008 | Audio Players & Recorders
DEH-P7900BT display issue
hey....alll you have to do is hold the "sourece" button until the unit shuts off, then push the wheel in until a menu shows on the display. scroll over until you see the "reverse mode" option...simply push either up/down or left/right to turn this off!!! NOW UR DONE!
Jan 12, 2008 | Pioneer DEH-P7900BT CD Player
Pionee DEH-P7900Bt
This may be a long shot but who knows... I am one of those that reads the manual after I have figured most things out. I had the same problem but it was due to the above :) When a call was coming in I was pushing the phone button on the receiver. After reading the manual I discovered that is the "ignore" button for incoming calls. To answer the call you simply push the multifunction knob.
Sep 15, 2007 | Pioneer DEH-P7900BT CD Player
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Pioneer DEH-P7900BT CD Player Logo
238 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
