Question about HP iPAQ rx5915
HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
The pc and laptop wont reconise that the ipaq is connected either by cable or bluetooth so it wont active sync. I have re-installed the active sync cd but to no avail
  • 38 Answers
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
Posted on Mar 27, 2009
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Active sync problem
check your anti-virus and firewall software - this can prevent outside connections being made over activesync
Nov 30, 2008 | HP iPAQ H1940 Pocket PC
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
Feb 15, 2008 | HP iPAQ rx1950 Pocket PC
HP IPAQ 2495
Try and reinstall the sync software in your PC. Check your cable if it is properly hooked.
Feb 12, 2008 | HP iPAQ hx2495
Samsung sgh-e900 usb connection problem
hi first things first
the e900 does not use use active sync that software is for pocket pc/pda ect
you need to download phone manager software for the e900 from the samsung site.
hope this helps
Jan 10, 2008 | Samsung SGH-E900 Cellular Phone
New sudden sync problem PDA with laptop.
got start> programs > active sync> open> then connect the usb cable...after phone is detected try to do sync. reinstall active sync can also help.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
IPAQ H5500 USB CONNECTION TO PC NOT WORKING
open active sync on ipaq and connect the cable with pc and ipaq. if not recognised perform a soft reset on ipaq. also check in  active  sync on pc >file> connection settings> allow usb connections is checked
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
Transferring Music
install Microsoft active sync 4.5 on ur pc then connect ur cell with data cable...it will help
Nov 15, 2006 | HP iPAQ RX3115 Pocket PC
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
HP iPAQ  rx5915 Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
