Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice maker not working, doesn't fill - Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
    Genius:
  • 1,122 Answers
REMOVE THE ICEMAKER COVER TO SEE IF YOU SEE ANY BROKEN PARTS,MAKE SURE THE ICEMAKER ARM IS IN THE DOWN POSITION AND ON,IF ALL THAT LOOKS FINE THEN IT IS THE WATER INLET VALVE ON THE LOWER BACK OF THE FRIG. THAT HAS GONE BAD-MIKE
Posted on Mar 02, 2009
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
Icemaker doesn't work
If the ice maker is not filling, you will need to replace the "water inlet valve" on the back of the unit. Here is the part you need to order.
Oct 31, 2012 | LG Electronics LDC22720SW 22 Cu. Ft....
MY GE MONOGRAM ZIS420D FREZZER IS NOT MAING ANY ICE. WHAT SHOULD I DO
check for continuity on the ice maker water fill solenoid valve in the lower rear area of the refrigerator,then remove cover from front of ice maker, and there are 2 gears inside this cover,follow the instructions on the ice maker by this gear and turn it the way it tells you to,this will initiate a manual ice production,you will see the gears turn by themselves after you help turn these gears initially,then you should see water enter from fill tube in the back of the ice maker if the fill tube isnt froze over,if no ice production occurs the ice maker thermostat could be open(bad) or if it makes ice but doesn't push it out the heater below the maker may be open(bad)
Aug 12, 2012 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
Ice maker is not working. No water is getting up to maker. Ice maker sounds like it is working. Tube in back has no water in it.Arm is down. Water is coming out of door just fine. There is no built in...
There is a screen in the water inlet valve where the water supply connects. OR The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 20, 2009 | Refrigerators
Our icemaker does not fill with water
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not getting water
Aug 30, 2009 | Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
