Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Software to hack wep
Hi
iwant strong software to hack secure wireless network secured by wep and another for WPA?please answer QUICKLY just iwant strong software
  • 40 Answers
Verifying your network security isn't a trivial task.
Although WEP has some know vulnerabilities which can be exploited WPA is significantly stronger, and can generally only be broken by brute force password cracking or other nefarious means.
You have not indicated your operating system however the following web page has numerous links and descriptions of some of the software available for Unix and Windows
http://www.windowsecurity.com/whitepapers/Wireless-Cracking-Tools.html
Posted on Mar 02, 2009
How do I set security on my DWL-952
There are 2 possible areas raised by this question. The first is a security patch needed to fix the firmware of your router, which by the way is not dwl-952. Your router is a di 954. Dwl 952 is a bundled router and network interface. The details of the firmware update are below.
Security patch for your D-Link router
These firmware updates address the security vulnerabilities in affected D-Link routers. D-Link will update this continually and we strongly recommend all users to install the relevant updates.
As there are different hardware revisions on our products, please check this on your device before downloading the correct corresponding firmware update. The hardware revision information can usually be found on the product label on the underside of the product next to the serial number. Alternatively, they can also be found on the device web configuration.
Please make sure you follow the firmware install guide provided within the ZIP firmware package.
DI-524 Revision E1/E3Thu, 28/11/13
The new firmware 5.13b01 that fixes the security vulnerabilities
DI-524 Revision Ex 5.13b01
Please note: please unzip the file and use the file DI524Ex_FW513B01.bin to update firmware.
DI-524UP Revision A1/A2Thu, 28/11/13
The new firmware 1.08b02 that fixes the security vulnerabilities
DI-524UP Revision Ax 1.08b02
Please note: please unzip the file and use the file DI524UPAx_FW108B02.bix to update firmware.
The second possibility is to set the local security on your network.
From the wikipedia page:
Wireless security is the prevention of unauthorized access or damage to computers using wireless networks. The most common types of wireless security are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA). WEP is a notoriously weak security standard. The password it uses can often be cracked in a few minutes with a basic laptop computer and widely available software tools. WEP is an old IEEE 802.11 standard from 1999 which was outdated in 2003 by WPA or Wi-Fi Protected Access. WPA was a quick alternative to improve security over WEP. The current standard is WPA2; some hardware cannot support WPA2 without firmware upgrade or replacement. WPA2 uses an encryption device which encrypts the network with a 256 bit key; the longer key length improves security over WEP.
The complete article is here
Wireless security
Log in to your router and find the wireless security section. Set up the security model that best suits your needs and then set up your wireless network card with the same information.
Mar 11, 2014 | Computers & Internet
I am trying to find what my wep key is but i cant
The WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 29, 2011 | Computers & Internet
Trying to secure wireless network
Welcome to Fixya. If you want to secure the network you all you need to do is to access the router settings page and put a security either WEP, WPA or WPA2 and a Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless, Select WEP, WPA or WPA2 and personalize a Security Key or Network Key (Passphrase). Security Key serves as a password on the network.
If you have questions please let me know. Thanks for using Fixya.
Mar 25, 2011 | Belkin (F5D7633UK4A) Wireless Router
The access point's security settings are not supported by the Nintendo DS
WEP and WPA are types of security that are used to protect home wireless networks. WEP is the only security setting that works with the Nintendo DS and Nintendo DS Lite. WPA and WEP are both compatible with the Nintendo DSi. If you are not sure how to find your router's WEP or WPA Key or if you have problems entering it into your Nintendo DS, try the following tips:
so if your wifi is WPA. you wont be able to use wireless
but if your wifi is WEP you can.
WEP is not recommended because it is not secure. Easy to hack
Mar 20, 2011 | Computers & Internet
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
How do I block other users from using my Modem
you need to lock the wifi use your house or cell phone number as a WEP key
Mar 02, 2011 | Arris SURFboard SBG900 Wireless Router...
Hi just iwant to put security # or password on my d- link router so imean nobody can can get acsses to the internet. thanks
WPA is a strong form of wireless encryption, however not all wireless adapters support this feature. If your wireless adapter does not support WPA you will want to use WEP to secure your wireless network.
You can find information on configuring your WBR router for WEP here
Step 1: Open a web browser and type the IP address of the WBR series router into the address bar (default is http://192.168.0.1).
Step 2: The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3: Click on the Setup tab at the top and then click on Wireless Settings on the left-hand side.
Step 4: Select the type of WPA encryption you would like to use with your wireless adapter from the Security Mode drop down menu. For WPA-PSK select Enable WPA- Personal Wireless Security (enhanced).
Note: All wireless products on the wireless network must have the same level of security to connect to the network.
Step 5: In the WPA Personal section, configure the following:
  • Select the Cipher Type
  • Select the PSK or EAP
  • Enter your Passphrase
  • Re-Enter your Passphrase
Step 6: Click the Save Settings button to save your settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I want to put a code to prevent other people using my internet
Please reset your Router or Modem-Router to factory defaults by keeping the reset button pressed for 10 seconds while the router is powered. Then, connect the router to the modem, and connect a computer to the router with an Ethernet cable. Run the Setup Assistant on this computer. The software is not strictly required to configure the Router or Modem-Router, you can also use the built-in web based configuration tool on http://192.168.2.1.
Then in the user interface find BASIC.From there in th Wireless Network Name put a name for your network.There are three wireless security modes, including WEP, WPA-Personal, and WPA-Enterprise. WEP is the original wireless encryption standard. WPA provides a higher level of security.Use WPA-Personal and in the Pre-Shared Key :use a strong mix key.
Nov 15, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hack wep
Here you do not find support for illegal activity.
WEP keys are used to protect privacy and I do not see any valid reason why someone would like to crack into a protected connection.
Mar 03, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
1,019 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
