Question about Fisher Price Toys
Ac adapter is not working on my rainforest swing
I have been using batteries in my rainforest swing now i found the ac adapter when i plug it in it dont work it makes no sound or anything i made sure the botton is turn to the plug in and not on the batteries one but it still not working what could be the problem?
There are 2 more wires that are available on the top left of the swing. You need to connect them together for the ac adaptor to work.
Posted on Aug 11, 2009
It won't swing. It has new batteries and is also plugged in through the ac adapter
I was watching it swing in your video! Cute Baby! If it is not swinging any longer, try to open the case. All that is inside is a small motor with a concentric cam mounted to a motor and a rechargable battery, oh, and an on/off switch. Use a small piece of wire or an alligator clip wire to bypass the switch. If it works, replace the switch. If not, check the output of the AC adapter.
Jan 11, 2013 | Toys
I have a HP Pavilion dv8225nr notebook pc and when I plug the ac adapter into the notebook the battery light keeps blinking and it wont hold a charge. When I keep it plugged in and I turn it on it wont...
It is most likely a bad AC adapter. One way to test it is to remove your battery (I put the steps to do this below) and just plug the laptop in with the battery removed. If it does not power up then your AC adapter is bad. You can buy new batteries online or at your local electronics store. I would advise against buying them from a store though because they are usually much more expensive. I did a quick google search and found some on amazon for a pretty good price.
http://www.amazon.com/HP-Pavilion-DV8225NR-Battery-Replacement/dp/B003KVZIQ2
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch to the left.
(The front edge of the battery disengages from
the computer.)
c. Lift the front edge of the battery up and swing it back.
d. Remove the battery.
Jun 17, 2011 | HP Pavilion DV8225NR Notebook
My battery doesn't recharge laptop when laptop is plugged in . What to do and at what approximate cost if new battery needed?
Hi there! There are two possible causes of the problem - it's either your battery or your AC Adapter. To diagnose whether or not it is your AC Adapter, test it this way. Does your laptop function with the power cord plugged in and the battery out? If this is the case, your AC adapter is fine and your battery is done. To replace the battery, expect somewhere between $75-$175. Here is a link to the cheapest battery site I've found so far - I use it for work all the time. http://www.batterydepot.com/mfg/TOSHIBA/LAPTOP-BATTERIES
If your laptop doesn't work with just the AC adapter plugged in, then that is your problem! AC Adapters are cheaper than the batteries. They can be purchased here for around $50: http://www.buylaptopadapter.com/toshiba-adapters.html
Make sure you match the model number on the bottom of your laptop perfectly with the model number of the battery or AC Adapter! Good luck! Alex
Apr 30, 2011 | Toshiba Satellite PSPA0U01S006 Notebook
How do you connect a ac adapter to the fisher price rainforest cradle swing?
Hi, the AC adapter connects through a wire that hangs out of one of the legs. You can see the complete instructions, including a diagram, in the owner's manual, which you can download from Fisher Price:
http://www.fisher-price.com/fp.aspx?st=2011&e=detail&selcat=bgsw&pid=51911
Scroll down to the bottom of the page and click on Instruction Manual, and the download link will appear. (If the link doesn't appear, try loading the page in Firefox rather than Internet Explorer.)
Oct 23, 2010 | Fisher Price Ocean Wonders Cradle Swing
My rainforest sounds swing j8518 doesn't make any sounds and the mobile doesn't move
If you have registered your product, and you contact Fisher Price, they will send you a replacement top - this will include the motor and mobile (with leaves). The A/C adapters and connection cords may also be to blame - these are common problems with this swing. We have had pieces of ours replaced many times - always free of charge from Fisher Price.
Aug 20, 2010 | Toys
I have a rainforest swing and everything on it
You can order the broken part and replace it. Call Fisher-price customer service and they will help you with that.
Apr 09, 2009 | Toys
Battery question
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Toys Logo
1,841 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
