Question about Singer 1120 Mechanical Sewing Machine
Thread bunching underneath
When i sew it will do fine then suddenly make a noise then the thread is all bunched up underneath.
  • 26 Answers
Clean the lint out with canned air and check the bobbin holder for any possible needle pieces from breaking a needle maybe the needle is bent and you can't see the slight bend.may need oiling too
Posted on Mar 08, 2009
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
Sewing Machine Thread Bunching Up Here Why
5 Common Causes of Birdnests
Why Do Get Bunched Up Thread Under My Fabric
Feb 04, 2016 | Sewing Machines
After sewing a few stitches, the machine gets jammed. the top stitch looks fine, but underneath there's a ton of thread all bunched up (top spool thread)
What you are seeing is called "bird's nesting." There are two main reasons for "bird's nesting."
The first one is the thread not between the tension disks. That allows the thread to be pulled from the spool instead of pulling the thread tight from underneath. Always make sure to always put up your presser foot before you thread the tension disks. I also check the thread after I finish to make sure the top thread has good tension on it before sewing.
The second reason is the thread is not being pulled by the take up lever. Make sure you see it being pulled by the take up lever before you start sewing. If not, rethread it.
Good luck.
Jan 02, 2016 | Singer 8280 Mechanical Sewing Machine
Top thread is bunching underneath
bunching underneath is an indication that the top tension is incorrect
switching projects and materials also that attention has to be given to tension adjustment both bottom and top
the catching sometimes indicates that a tension is too tight and is pulling the needle out of line
Jul 25, 2015 | Sewing Machines
Sewing bobbin
Found several answers at this site, mostly addressing the tensioner.
Singer Sewing Machine Bobbin thread is bunching up Yahoo Answers
Jan 14, 2015 | Singer Sewing Machines
My machine is noisy seems stiff and the thread is bunching underneath bobbin case seems loose
It may need a cleaning and lubrication to resolve the noise and stiffness.
as to the thread bunching on the bottom, try re-threading both the top thread and the bottom thread, if it persists, try a different bobbin, (the one your using may not be wound properly, it happens) If it still persists try a new needle. if all of this fails, take the machine to a reputable service facility, it usually helps to take a sample stitching to show them exactly what it's doing to you,
Good luck and happy sewing!
Aug 12, 2014 | Sewing Machines
Brother pe180d thread bunching up underneath
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Dec 02, 2012 | Brother Disney PE-180D Computerized Sewing...
Everytime I try to use my machine the thread bunches up underneath
Nov 26, 2012 | Husqvarna Lily 540 and 550
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
Singer 1120 Mechanical Sewing Machine Logo
271 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
