Question about Maytag Washing Machines
Maytag washing machine PAV3360AWW Won't stop
Maytag washing machine PAV3360AWW Won't stop filling with water
  • 106 Answers
Your inlet valve is defective, can be easily changed by you. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Is it when you turn on the machine, if this is the case check to see if the exit hose behind is approx 3 feet (it should be) above the ground, & then goes down to the drain. The hose should not go into a drain at floor level.
Sites for spares: (which is good)
Posted on Mar 02, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
The water won't stop filling up the tub causing it to over flow.
it could be the pressure chamber is blocked up with old hard soap or the pressure switch is jamed
May 28, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Maytag heavy duty super capacity washer - stopped mid cycle. Won't drain water. Won't agitate. Water fill function works. Any ideas what to check? Do you know where the fuse is located?
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Jul 16, 2011 | Maytag Washing Machines
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 06, 2010 | Maytag Washing Machines
Maytag washing machine model PAV3360AWW won't stop water on selected water level.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
Dec 30, 2008 | Maytag PAV2300 Top Load Washer
My maytag Performa PAV3360AWW had three problems going. It quit agatating and spinning, and the water keep filling and overflowing. We replaced the belt, and also discover that a hose had come lose on...
please bear with me as i am committed to help you. but i need to know if the motor is running while it is trying to spin or if it is silent. if the motor runs but no spin then you may need a transmission pulley repair kit (approx $30). or if is silent then you may need a lid switch.
let me know if you need more help
Jul 04, 2008 | Maytag Washing Machines
Open Questions:
Washing Machines Logo
154 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
