Question about Brother BRTPT65 PT-65 Label Maker Printer
Cannot remove backing
I have a Brother PT65 and have not used it for some time. I printed a label but cannot remove the backing. Do all the labels have backing? If so, how can I remove it?
    Genius:
  • 2,120 Answers
Bend the label in half length-wise
Posted on Mar 02, 2009
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
My Brother PT65 label maker powers up and when I push print...the rollers turn but the label does not print or come out.
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
May 20, 2015 | Brother BRTPT65 PT-65 Label Maker Printer
When printing a label on brother QL-1050 printer comes up with error "Either BOF or EOF is true or the current record has been deleted Requested operation requires a current record" I have removed...
I solved this problem by pressing "Control N" to bring up a new label. Works fine that way.
This is the answer Brother gave when I called them:
Description of Problem 100000003722
When I click print I receive the error message: Either BOF or EOF is true, or the current record has been deleted.
Description of Solution 200000004488
This error message occurs when you print a label that has no record in the database table.
To avoid this error message, click on Database menu, select Create New Record.
Oct 09, 2010 | Brother QL-1050 Label Printer
I want a manual for this product here, in the internet
The manual for the PT65 can be found at the link below.
http://www.ptouchdirect.com/ptouch/manual/PT65.pdf
Robert from Blitware
Jun 15, 2010 | Brother BRTPT65 PT-65 Label Maker Printer
How to print adhisive labels using mfc 7340
Buy laser-specific adhesive labels. Those that say "Laser printer compatible". If you have an inkjet printer, print the labels with it, with the laser is more risky because of the temperature the paper needs to get in the printing process. If one label gets out of the support paper or the paper gets sticky inside the printer, it will cause a real mess.
Try inkjet first, or buy high-quality labels and print one full sheet at a time, not label by label.
Oct 28, 2009 | Brother MFC-7340 All-In-One Laser Printer
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
With a pt 65, how do I reduce the size of the print?
Cook,
With the unit powered up, press and hold the yellow Code button. While holding it down, press the & key and watch the pointer at the top of the screen. Note how it is moving to the various size As. That will increase and decrease your font size.
Mar 05, 2009 | Brother PT-65 Personal P-Touch Electronic...
Printing envelopes and labels
I foubd the Brother website to be very helpful with my label and envelope printing:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_007.html?reg=us&c=us&lang=en&prod=hl5240_all&Cat=4
Apr 01, 2008 | Brother HL-5240 Laser Printer
Labeling system trouble-shooting
I thought the PT65 took a thermal tape that didn't have an ink ribbon. Compare the part number on the tape cassette with the list of compatible types listed in the labeller's instruction manual. Believe the only compatible cartridges are: M-Knnn/B, where NNN is one of 221, 222, 223, 231, 232, 233, 521, 531, 621 or 631, or M-K221S/B or M-K231S/B A.
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Brother BRTPT65 PT-65 Label Maker Printer Logo
152 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
