Question about Dell (E210882) Motherboard
M system needs to be bang on before it comes on
At times my computer will boot normally but some times i need it hit on the power botton before it comes on. at times it starts booting but goes off. i dont know if it is a problems with the power botton or something else
STOP BANGING IT ! AND TAKE IT APART TO FIND THE PROBLEM YOU WILL KILL YOUR HARD DRIVE !
Posted on Mar 03, 2009
No bootable devices
Make sure you don't have anything in the CD/DvD Drive. It sounds like your system is trying to boot from something other than your hard drive.
Turn the system off then press the power button to restart it. Watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence and hit that key when you see the message. Select the Hard Drive as your boot device and let it boot up again. This is a temporary change that is only good for the current boot cycle.
It the system boots then you want to restart the computer and this time watch the screen and see which key it says to hit to get into the Bios or System Setup and hit that key. When it opens tab over to the Boot and set your boot order or boot sequence to have the CD/DvD drive 1st and your Hard Drive 2nd. This is the normal way so that if your hard drive ever fails to boot you can put a cd in the drive to remedy the problem. Otherwise, just make sure nothing is in the cd/dvd drive when you turn the boot the computer.
May 13, 2012 | Dell Inspiron 1525 Laptop
Selected boot device is not available
What are you trying to boot from? It sounds like you selected something other than your hard drive.
When you power on the computer take note of which key it says to hit to Change the Boot Order or Boot Sequence and hit that key. This is a one time change that will get you booted up. You should select your Hard Drive to boot from.
To make the change permanent you will have to get into you Bios or System Setup. Reboot the computer and notice what key it says to hit to get into the Bios or System Setup then hit that key. When it opens up, hit the tab that lets you change the boot sequence or boot order then save it and exit out. Normally you want the DvD/CD drive 1st and the Hard Drive 2nd. This way if your system has problems you can insert a repair disk or operating system disk to fix it in the drive. The only drawback is that you need to make sure nothing is in the CD/DvD drive when you boot up (such as a music cd or movie dvd) or you will get a message telling you that it can't boot from the device.
If you like, you could just make the Hard Drive as your first boot device.
May 09, 2012 | Dell OptiPlex 360 Desktop Computer
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click start > all programs > accessories > system tools > system restore
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
Hi I have a dell inspiron 1525 and it always worked fine but now when I go to turn it on the start up repair comes up and runs. Then a window comes up that says "startup repair cannot repair this computer...
The first step would be to: When the black screen with white text comes up with two options: star-up repair and start windows normally, press the down arrow followed by enter to attempt to start windows.
if this works then you are done. If not, press F8 repeatedly as soon as you power on the computer (before the black and white screen comes up). This will give a much larger range of options than the normal two. Select the top-most option, "Repair your computer". This will be a different repair than the norm. It should bring up a window which list many options one of which is system restore. Click this option and follow the prompts attempting to restore the computer to an earlier date. It is likely that this will undo any erroneous changes causing issues. The computer should automatically restart and boot to windows.
//halfs
Sep 02, 2010 | Dell Inspiron 1525 Notebook
My Acer Aspire 3000 notebook won't start Windows, it just goes to the screen where it says, "Start windows normally" etc. Whenever I click one it takes several minutes, then restarts, what do I do?
Try this, you will need a windows installation disc to perfrom the repair.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Jul 02, 2010 | Acer Aspire 3000 Notebook
I am using windowsxp on my pc its not opening computer only giving ctrl and alt and del i press those three bottons after pressing the botton it comes again and again how to solve this case
Hello Manivannan Hi!, there is a problem with your Hard Drive, there is no Operating System (windows), OR there is no BOOT device. check for loose connection both the IDE/SATA cable and power supply molex connector, you need the HD be detected by the PC. Pop in the Windows CD on your CD drive, reboot your PC, press F11 to go to boot options, and select CD. let me know your progress.
Apr 26, 2010 | HP Compaq Presario C700T
Black blank screen
Try the below fix to repair the windows boot.ini file and return windows to start normally......
C:\Windows>
cd \
C:\>
CHKDSK /R
Hit the enter key.
FIXBOOT
Hit the enter key.
Nov 29, 2009 | Computers & Internet
Power up lapton and received Operating System not
chech to see that no disk is inserted into the cd drice and the floppy drive.
there must be a system file missing
might have to reboot the system
if nothing comes up them there is a problem with the hard disk or the operating system is not fully installed
Oct 09, 2009 | Sony VAIO VGN-FS630/W Notebook
I need the code to program my dish network remote for the Polaroid 42 inch LCD television
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
Dec 02, 2008 | Televison & Video
Hibernating I guess
boot your computer in safe mode and in display properties>Screensaver>Power tab>Advance>
"When i press the power botton on my computer " select "do nothing" and " when i press the sleep botton on my computer " select "do nothing"......
then press ok and apply then restart your computer in normal mode it will work
Jun 12, 2008 | HP Compaq dc7100 PC Desktop
Dell (E210882) Motherboard Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
