Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Router problem I hooked my router to my pc. It shows that it has internet but, my computer doesn't have internet now.
  • furry3446 Mar 02, 2009
    Thanks for the help it didn't work at first but I did a powercycle and it worked.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Posted on Mar 02, 2009
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
Is there a way i can hook up internet to 2 desktops with 1 modem/router?
That is exactly what a router is for.
If your modem doesn't have multiple ethernet connections, then go out and buy a generic router (like linksys or belkin or cicso or netgear, etc.) and hook the WAN port of the router to the modem's ethernet connection, and then hook the computers into the multiple ethernet connections on the router.
Aug 24, 2011 | Computers & Internet
The router doesn't recognize the dsl modem. I have hooked up to the internet directly from the computer and modem-no problem using the same cable the router can't connect to the...
connect the Ethernet Cable to lan Port and make new connection from Window (PC also should connect to the Lan Port) and configure the username and Password (test it ) if it is going this mean the Wan Port Has some Problems......
Jul 12, 2011 | Computers & Internet
I have a wireless router and a pc down stairs not hooked up to the internet how do i get it hooked up with the router hooked up to another pc upstairs
if you can conect a ethernet cable to the router then to the pc you will have internet. if the router or pc dont have a ether port free or avaiable. you can buy a wireless usb dongle. plug this into your pc witch will make your pc wireless and then u can conect it to your wireless modem. hope this helps in some way.
Nov 30, 2009 | Compaq Presario 5000 PC Desktop
For some reason when I hook the Router up I can not get onliine on any computer that I have the router for. I just moved and it worked fine at the last place. But the system light blinks. I forget if that...
Blinking shows activity, Double check how you have it hooked up....If you are using Internet connection sharing you should have your modem hooked throught your pc and your pc hooked to the #1 slot on the router...If you have your router connected to the modem its self make sure that you have it connected to the internet port of the router......If this is all set up properly hit the main reset (little black button on the back of the router) hold it for 30 seconds. Another possibility is firewall conflicts. Get back with me and let me know if this worked out for you...If not there are alternate directions we can take to solve this issue as it can be a number of things
Oct 06, 2009 | Dynex DX-E401 Router
Router isnt working
Check the network connection physically, if your connected properly then nothing happened? check the lights of the router? if the link lights of the router is not lit you needing to get an another router.
Mar 25, 2009 | Computers & Internet
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Router not hooked up properly
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Connection keeps going on and off
check the ip addresses with the pc downstairs and see if all the pc's have the same default gateway. If not check your network card or network cable.
May 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
169 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
