Question about Canon L220 Plain Paper Laser Fax
Daily report/printout I need a printout/report at the end of the business day of all faxes that were received and send out. How do I change the settings?
  • 318 Answers
At the end of the each day,press funcktion and then report,select activity report and press "ok"
This is the only way the activaty report can be printed at a spesific time.If you switch the report on in the report settings it will only print when the memory is near full.The other way is to switch TX report to on in report settings,but the you will get a report after every fax that you sent.
Posted on Mar 05, 2009
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Cannot fax to one number
PROBLEM IS NOT YOUR FAX 99%CHANCE IT IS THE PHONE LINE CONNECTION WHEN YOU DIALTHE SIGNAL IS GOING TO VARIOUS LOCATIONS LOOKING FOE FREE SPACE TO SEND TO RECEIVING FAX.BEFOR RESENDING TRY CALLING FROM PHONELAND LINE.COMMUNICATION ERRORS ARE THE BIGGEST FAX PROBLEMS IF THEY CANT COMMUNICATE 95%ERROR FREE THEY WILL DISCONNECT STATIC ON LINE IS THE CAUSE
May 19, 2010 | HP 1040 Plain Paper Inkjet Fax
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Could not receive and send Fax
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= r.trip@alice.nl
Let me know is you encounter new problems?
Greetz
Richard Trip
Jan 16, 2008 | Ricoh Aficio SPC210SF All-In-One Laser...
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
Canon L220 Plain Paper Laser Fax Logo
285 people viewed this question
old marine
old marine
