Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Problem for Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
My 5316 copier keeps blinking F2 and willnot print
By eldoredos7 on Mar 02, 2009
my 5316 copier keeps blinking F2 and willnot print I have changed my developer still it keeps showing F2
Solution #1
posted on Mar 02, 2009
Not Rated)
jpd8
Rank: Guru
Rating: 88%, 73 votes
F2 - Black toner supply trouble
Try a different toner cart, remember to shake the cart. before installing. Power the machine on and off and check. Check the sealing tape has been fully removed from the cartridge as well as the green colored plug.
Also, if you have an original drum unit frame, change the frame with the new Modified version to prevent arching at the rear cover of the drum unit against the inside back plate of the machine.
Check that the black dev. tank is not low or empty, re-position both drum & dev. tank.
Pls rate - Thank you
Was this helpful?
Yes
No
Popular Solutions for Sharp -COPIERS - AR-5316
Questions and Unsolved Problems for Sharp -COPIERS - AR-5316
Do you recommend Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier?
Answer
Answer
I install the cartridge then machine was warming and show the code F2
Answer
im facing one problem if e 004 service code for canon 7161 what is the solution?
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in , IL
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
