Question about Nokia N-Gage QD Console
How am I going to repair my n gage the problem is when i open my phone it will open in just a second after that shout down next and it open again continous open close i hope you can help me with my problem thankz alot
  • 34 Answers
It seems that your phone OS has a problem. You can go to any nokia care centre and ask for there assistance. The cause of the problem may be virus or something else. Go for the nokia care they may handle your problem.
Posted on Mar 02, 2009
Temperature gage mid point will go back down and back up. heat ok.
You have a sticky "thermostat" valve.
It should stay "closed" until the engine warms up,
then open, to allow more coolant to cool the engine down.
If it is "slow" to open, your engine gets too hot, until it does open.
Then, the coolant cools down the engine, until the thermostat finally closes again.
Feb 24, 2015 | Cars & Trucks
Camry 96 model overheating
-Is your car running fine and just over heat...?
Here there are few things that need to check:
Q:-Is it full of coolant (Water)?
A: -No Add more water untill full and ran your car again.
Q: Problem solve...?
A: -Yes. (You're done)
-No. Go to the next step
-Check the thermostat . Is it function at a certain temperature?
(This Mean take it out from the car and boil it, use a temperature gage
watch when you boil. It start to open at what degree) If not open at all
or open at too hight. Replace it.)
Good one should start open at 180 to 190* (Must be full open)
-If the engine is normal, but the temperature gage keep going up. It could be effect the temperature sensor itselt.
mai Lor
Feb 22, 2013 | 1996 Toyota Camry
My samsung R540 pc will start for a few seconds and shut down again
It sounds like your power supply has died. I would suggest a replacement.
You also may need to reseed your ram as that may sometimes be the issue.
Aug 26, 2012 | Samsung R540 Laptop
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
My iphone shout down
First plug it in to a power source to charge it. It might have shut down due to a lack of battery power. Once you have done that, hold the home and sleep button at the same time for 8 seconds or until you see the apple sign. If this fails to get it up and running you may need to connect it to iTunes and have iTunes recognize it.Then you will have to try restoring as a NEW iPhone and see if the problem persists. If you can get it to turn on then you're fine, if not, I would recommend visiting an Apple store soon.
May 01, 2011 | Apple iPhone 3GS Black (16 GB)
Im using SE x10mini pro. it was not charging when i connect to charger or usb cable a red light blinking on the top.. for some time it atarts booting and again shouting down...it was repeating...
Do reset your phone hope it will sort out your problem. for reset just do...
Sony Ericsson have added a nice little reset button, just below the back cover. Press and hold this little button for a few seconds, and it'll be like if you removed the battery and put it back again.
Another way to force a reset should be by pressing the middle button and the power button at the same time for at least 5 seconds...
Thank you...
Apr 21, 2011 | Cell Phones
I have a 1993 Acura Ledgend. For some reason my heater does not continue to blow hot air, it does for a few minutes and then begain to blow cold air. It does this often now. It works and then it blows cold...
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Nov 30, 2009 | 1993 Acura Legend
2003 Avalanch fuel gage
You have a problem with the stepper motor gauge that Chevy used in the 02-06? Avalanche. All the gauges use the same stepper motor. They just go wonky and do all kinds of weird things. I have replaced two on mine already and two more are now acting up. There is a guy selling the motors and the repair for this problem on E-bay.
Jan 16, 2009 | 2004 Chevrolet Avalanche
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Nokia N-Gage QD Console Logo
59 people viewed this question
Top Nokia Video Game Consoles & Games Experts
marley mcelhinney
matt
matt
Are you a Nokia Video Game Console and Game Expert? Answer questions, earn points and help others
