Question about Cfm Daikin R410a Split System Air Conditioner
Will you tell me the electrical diagram of 12 floor standing vrv daikin?the model of indoor units are fxlg63mave and the outdoor units are rxyq12p7ylk rxyq10p7ylk rxyq8p7ylk
  • 1 more comment
  • Fotis Papastamatiou Mar 13, 2009
    i get past the pipes and the cambles first to the vrv system and i haven't the wire diag.
  • Fotis Papastamatiou Mar 28, 2009
    the vrv daikin system is inverter ac
  • Anonymous Mar 18, 2014
    It is not starting
    Guru:
  • 462 Answers
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
  • 1 more comment
  • Farley Redfield
    Farley Redfield Mar 13, 2009
    What does the indoor unit and outdoor unit do? Is this an AC or a Refrig or a furnace??
  • Farley Redfield
    Farley Redfield Mar 28, 2009
    OK sorry I don't know about that type of appliance. Had I known the R410 was not in reference to refrigerant I would not have assumed this to be a Heat Pump or AC. Inverters are beyond me as of right now. But in a few weeks... Sorry.
  • Farley Redfield
    Farley Redfield Mar 30, 2009
    ac to me is Air Conditioning and R410 Ia a refrigerant in the newer systems.
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
How to reset daikin vrv 111 air condition
Pull the disconnect for 10 seconds on the outdoor unit.
Jul 03, 2017 | Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
585 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
