Question about Lexmark X3350 All-In-One InkJet Printer
Lexmark X3350 - Will not print
Says ink low but just loaded new cart.........?
Have reinstalled printer
Have loaded new drivers
Checked leads - all OK
Can print test page ?
  • 109 Answers
If this is a brand new cartridge right out of the box and it doesn't work, check for any residue from the blue tape you removed before installing it. If it still fails, I would assume it is defective and return it for a replacement.
Posted on Mar 02, 2009
Printer just stopped printing although my computer tells me everything is ok and printer is 'ready'. Still copies OK, and printed ok earlier this morning.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
When printing on x3350 with a new cartridge... get lines that are double and some with thick black ink on some letters.
Try to reseat the cartridges into the printer. If problem continues, then maybe the cartridge nozzles need cleaning. Follow the simple steps below on how to clean the cartridge nozzles on the Lexmark X3350:
  1. Go to Start, Programs (Windows XP: All Programs) > Lexmark 3300 Series > Lexmark Solution Center.
  2. Click the Maintenance tab.
  3. Click Clean to fix horizontal streaks.
  4. Click Print. A cleaning page prints, forcing ink through the clogged nozzles to clean them.
  5. Print the document again to verify that the print quality has improved.
Source: How to Clean the Print Cartridge Nozzles on the Lexmark X3350
Jul 13, 2011 | Lexmark X3350 All-In-One InkJet Printer
No color ink
To solve this issue what u can try is remove the ink cartridges from the printer. Unplugg and replugg the power cable. Clean the copper contacts of the carts using a dry paper towell. Snap the cart back to the printer and install the cart as the new cart. Print the alignment page. Also uninstall and reinstall the driver using the original CD, sometimes Windows can change to an "updated" driver with Windows update. It may have installed a B&W driver.
If all this fails it might be the issue with the encoder strip. Call Lex Tech Support and get help to fix the encoder strip.
Mar 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P3150
Some people have success with varying brands of generic carts, some don't. You can try copying many pages of anything many times. say 50, then run head clean routine. Repeat up to 250 copies. If after this still white pages, get genuine carts and repeat until it works. If no go the head is probably clagged up with generic ink. Then you need to pull it and soak, but don't hold your breath.....
Apr 27, 2009 | Lexmark X3350 All-In-One InkJet Printer
Printer wont print - Urgent
Does it print a test page from it's own menu? This will isolate whether the problem is internal or from the connection to PC.
If it prints internal page, then try reinstalling driver.
Mar 01, 2009 | Lexmark X3350 All-In-One InkJet Printer
I have lexmark printer x3350 that i'd got from a
Just go to Lexmark.com and click on support and drivers type in the model of printer and it will give you the software you need.
Feb 22, 2009 | Lexmark X3350 All-In-One InkJet Printer
Printer Ink is Low
If had refilled the ink then this printer as in build sensor which works only once , that reasons your getting this message if your using original Lexmark cart then if your getting this message then you can contact lexmark get the cart replaced as the cart comes with 6 months warranty.
May 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Can you help me please!!!!!!
Replace refilled ink carts with proper gen ones cause it sounds like the refill was not so good, print out photos next door till shops open.
Oct 29, 2007 | Lexmark X3350 All-In-One InkJet Printer
Lexmark X3350 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
