Question about Landice L7 LTd Pro Sports Trainer Treadmill
Lites on control board read ( L 5 ) when machine is turned on.
Motor will not run ! power first model T960 motor not running coming up E1
  • Anonymous Mar 24, 2014
    my ice run running machine overheated so i fitted a new PCB board and motor and now it blows the main breaker when switched on
    Problem Solver:
  • 14 Answers
The e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Posted on Mar 02, 2009
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Exercise & Fitness
Cardiotech x7 e1 code
test the input terminal motor, if there are the motor is faulty, see my personal TIPS 2) test the output voltage from control board, if there ARE NOT for input voltage motor, the board is faulty. see the diagram attached. 3) the error coming from speed sensor, Run the software calibration for easy diagnostic and fix it. However you must LUBE the deck belt,+rollers bearing front +back see the video attached.
God bless you
Nov 27, 2013 | Exercise & Fitness
Model: Acer Aspire E1-571 The battery had
The battery may have failed even though new.
Apr 24, 2017 | Acer Aspire E1-571-6650 Laptop
My Powerfirst T960 stopped twice while running. Display stays on (no error message) but backlight turns off. Also, was speeding up/slowing down while running
1)LUBE THE DECK BELT, this problem is by lack of maintenance schedule, maybe you have deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for protect the electonic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board, for the input voltage motor, if there are NOT the board si faulty.
5) RUN the software calibration for diagnose, troubleshooting and fix it.
see my person TIPS for help.
sincerely. God bless you
Apr 18, 2012 | Exercise & Fitness
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
My Power First T960 stopped whilst I was using it and come up with an E1 error. I have lost my users guide so I don't know what this means. Help please!!!
Dear Sir:
I will help you inmediately, do not go in panic:
1) Check is voltage is o.k 115VAC, measure with a VOM(Voltimeter)
2)Try again, if is working. If donot check the c. breaker or fuse.
3) Is everything is o.k the faulty is VSD(Variable Speed Drive) the give the ERROR I.
4) That means the VSD is defective, try to put some special liquid for to clean Pot or contact, and check again.
5) If not you must return the PCB, to the factory indicating the Code ERROR for to fix easy.
Thank you in advance , blessing , sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Sep 13, 2011 | TEKK Exercise & Fitness
Have E1 problem,machine stopped running,replaced washerpump/motor,runs for a few minutes E1 comes up and machine stops,any ideas
I had the same problem, new wash pump didn't solve the e1 error. New capacitor did the trick. Hope this helps
Jan 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
I have a Freespirit Treadmill...Model l# JM05-001. I was using it and it just shut off giving error message E1. I turned it off and restarted it. Belts are working fine and did not use incline. It runs...
Don't laugh, but I'm working with an old Athlon Simplicity model to try and adapt the motor to a band saw. In any event. There is a magnet imbeded on the outside of the front belt roller. It triggers a circuit that counts the revolutions. There should be a small postage stamp sized black plastic piece near the belt roller that has two wires running to the circuit board. It may have come unplugged somehow. When I unplug mine - the motor stops and it displays E1.
Jan 15, 2011 | Sport & Outdoor - Others
Error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
Dec 31, 2008 | Heating & Cooling
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
Landice L7 LTd Pro Sports Trainer Treadmill Logo
923 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
