Question about Nokia E50
Bluetooth is not working in my mobile model no.E-50 transmite & receiving problem
    Problem Solver:
  • 8 Answers
Try to re-install the software through Tornado box, if this does not solve the problem, then Bluetooth module needs to be replaced which is hardware part.
Posted on Mar 06, 2009
Games
Posted on Apr 21, 2009
Why does Bluetooth reception tend to skip and cut out randomly?
Hi
Usually the range of the Bluetooth transmission/reception is 10m max...
if you are transmitting above this rang it would do this interruption and noise.
another case.... it can be that the Bluetooth receiver is a bad quality.
hope this helps understanding the case.
Good luck
Dec 03, 2015 | Denon AVR-1100 Receiver
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
I can't recevie any files from bluetooth just send to mobile what can i do ?
If you are using the MS bluetooth stack, you must explicitly prepare your notebook to receive the file. You must have bluetooth icon in the notification area. Right click it and select something like 'Receive file' (sorry for not being more specific, since mine is in Portuguese). Only then, send the file from your mobile.
Hope it works for you.
Just my 2 cents...
Regards, Carlos
Sep 24, 2010 | Acer Aspire 5720-6661 Notebook PC
Recieving an invaild pointer address message when
try looking for bluetooth and make sure your phone is compatible with it
Jul 19, 2009 | Adapters.com Bluetooth USB Adapater, USB...
My new samsung e1410 mobile have probleam with bluetooth .I can't able to send file via bluetooth to any other mobile.where other mobile able to send them that files from their mobiles but I can't able to...
Your phone might not support blue tooth file transfer. Call your service provider and ask, they should be able to tell you. Also the file you are trying to receive/send might be to big
Jun 29, 2009 | Samsung Cell Phones
I would like to know if my laptop has settings for bluetooth entrance and how to get there?
What Is Bluetooth? blob1.gif Well it isn't some strange form of tooth decay as you might initially imagine. Bluetooth is the name of a new technology that is now becoming commercially available. It promises to change significantly the way we use machines.
Take a look around Look around you at the moment, you have your keyboard connected to the computer, as well as a printer, mouse, monitor and so on. What (literally) joins all of these together?, they are connected by cables. Cables have become the bane of many offices, homes etc. Most of us have experienced the 'joys' of trying to figure out what cable goes where, and getting tangled up in the details. Bluetooth essentially aims to fix this, it is a cable-replacement technology
2 How? Conceived initially by Ericsson, before being adopted by a myriad of other companies, Bluetooth is a standard for a small , cheap radio chip to be plugged into computers, printers, mobile phones, etc.A Bluetooth chip is designed to replace cables by taking the information normally carried by the cable, and transmitting it at a special frequency to a receiver Bluetooth chip, which will then give the information received to the computer, phone whatever.
3 How about ? That was the original idea, but the originators of the original idea soon realised that a lot more was possible. If you can transmit information between a computer and a printer, why not transmit data from a mobile phone to a printer, or even a printer to a printer?. The projected low cost of a Bluetooth chip (~$5), and its low power consumption, means you could literally place one anywhere.
4 Ideas, ideas... With this viewpoint interest in Bluetooth is soaring, lots of ideas are constantly emerging, some practical and feasible e.g.: Bluetooth chips in freight containers to identify cargo when a lorry drives into a storage depot, or a headset that communicates with a mobile phone in your pocket, or even in the other room, other ideas not so feasible: Refrigerator communicating with your Bluetooth-enabled computer, informing it that food supply is low, and to inform the retailer over the internet.
5 The future, this website Whatever the ideas, Bluetooth is set to take off. To be honest it's going to be forced down the consumers necks, whether they want it or not, as too many companies have invested in it. This website is generally geared towards the technical issues surrounding Bluetooth, and its implementation in real life. But free feel to have a look around anyway, and see why this technology will have such a big impact on our lives. If you're a complete beginner & you want to know more go to the other pages on the website: the Tutorial has a reasonably in-depth guide to Bluetooth (can be quite technical in parts though), our members-only Download** page has some more general introductions to Bluetooth to download. Also check out the Resource Center, Articles, Glossary & Knowledge Base to further enhance your Bluetooth education. There are also related Resource Centers on IEEE 802.11 WiFi Wireless LANs, HomeRF, GPS, SyncML, ZigBee and other mobile and wireless technologies. Enjoy!
Jun 05, 2008 | Computers & Internet
Fj-800 bluetooth headset
I have such a pair and they work great. As soon as I turn them on, they connect to my phone and my phone (Nokia N95) unpauses the music - instant bliss.
Mar 29, 2008 | Audio Players & Recorders
Mobile XT not excepting my GPS Receiver
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any Pharos GPS receiver.
Dec 31, 2007 | Palm Treo 700w Smartphone
Bluetooth has stopped transmitting
Make sure your version of bluetooth for the hand held device and the listening device is not an old version. The first generation of blue tooth was able to transmit sound (for phone calls), but not able to transmit stero sound or mp3.
Sorry I couldn't be more helpful... :)
Dec 11, 2007 | RIM BlackBerry 7100G Smartphone
Nokia E50 Logo
79 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
