Question about Nilfisk Vacuums
How do I get my vacuum cleaner to blow air instead of **** air? I want to use it to blow up an air bed - Nilfisk King 240
3 Suggested Answers
  • 389 Answers
SOURCE: Is it possible to make
Sorry, but the short answer is: no!
Posted on May 01, 2009
MNfisherman
  • 11896 Answers
SOURCE: I need to replace the
The screws are most likely in the back of the unit, there may be 6-9 screws. After any screw you see on back of machine is removed, then you can pull apart and access the cord and switch. The bottom of machine may have screws on very bottom. THere is probably about 4 screws on the bottom holding cover on.
Posted on Aug 25, 2009
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Our Rainbow SE PN2 is blowing instead of sucking, is there some kind of airflow adjustment that we need to do?
Kellie, I've had 2 Rainbows and the only way I know that they can blow is if you have your hose attached to the outflow(exhaust) for such things as blowing up air beds water toys, etc. If your hose is on the front of the machine and it is still blowing air....I got nothin'! That seems very odd to me, and I've never been told even when I sold the machines that there was any type of airflow adjustment for them, especially on these older models.
Sep 21, 2013 | Rainbow Reconditioned Canister Bagless SE...
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
Vacuums Logo
199 people viewed this question
Top Nilfisk Vacuums Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
