Question about Apple iPod nano
Ipod won't sync to Itunes
Hello, I am having an issue with my Ipod. It gives me an error code when I plug it in saying that it cannot sync because the files or directory has become corrupt and unreadable. Someone on the Apple site suggested (to someone else with a simular issue) that this could be caused by locked files in the directory. I am good at following step-by-step instructions, but have no clue how to even access this directory so I can *see* if anything is locked. Any ideas? Thanks!! I just boughtit and it doesn't sync to my computer! I has tthis signal that it turns on when i sync it but it doaen't even have the "Do not disconnect" sign!
  • 81 Answers
You should have updated your ipod software in piracy please try to load an original one
Posted on Mar 02, 2009
SOURCE:
Error code 1140
Yes, I have had this problem. First, I would disable the automatic sync with the iPod and ITunes. You can do this by going into preferences in iTunes. Download the latest version of iTunes by checking for an update. Then click on your iPod in iTunes and restore the iPod to its original setting. This will erase the whole iPod. Then you can sync it with iTunes again. That should fix the problem.
Jul 09, 2012 | Apple iPod nano
Does your ipod actually work or no?
if it works put it in disk mode by pressing the menu and center buttons and holding until the apple appears and switching to the center and play buttons and holding until the check mark appears.
then plug it in the the usb and see what happens.
if it mounts to itunes try and restore. if not go to my computer and see if it is there. if so right click on the drive and format...not quick format use full format.
then repeat the steps before until you get it mounted.
more than likely you have a virus and the virus is not letting the restore program delete it.
May 20, 2009 | Apple iPod classic MP3 Player
Because you have all your music already backed up onto your pc you can safely erase your ipod. Have you already tried to do a restore on it yet. To do this connect the ipod to the pc and in itunes on the ipods main screen click the Restore button, then choose the bottom most option if it gives you any. If it says to erase the device anywhere, all the better, select that one.
If that doesn't work, assuming you're on a pc and not a mac, open 'My Computer', right click the ipod, select 'Properties' then erase it as you would any harddrive. Once you have done either of these you can resync it in itunes.
All the best
Sean
Dec 21, 2008 | Apple iPod touch
When you wiped the old computer and then reconnected to the new computer, it reformatted the player, causing data corruption. I would try all five of these suggestions, but first try uninstalling and reinstalling all Apple/iTunes software: Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
Sep 08, 2008 | Apple iPod nano
Hey try plugging in your ipod and then go to the ipod thing and hit restore ipod and then once it is done then try to sync your ipod
Sep 07, 2008 | Apple iPod nano
give it a soft reset if this is not solve the prob
give it a firmware upgrade
u can find the upgrade tool and the F/W
on ur website support area
plaese rate this post!!
Aug 18, 2008 | Apple iPod nano
maybe - just maybe - if you plug it into your computer and then, if a mac, do the 'get info' bit and look for the info regarding if a file or device is locked.
Jun 13, 2008 | Apple iPod nano 3rd Generation
THE SOLUTION IS EASY, REBOOT YOUR IPOD! IT WILL WORK! I JUST SPENT DAYS GOING CRAZY ABOUT THIS!!! I CALLED APPLE TWICE AND THEY TOLD ME TO REINSTALL AND UPDATE BUT I DIDN'T DO ANYTHING..
THEN I FOUND SOMEONE WITH THE SAME PROBLEM AND ALL THEY DID WAS REBOOT THEY'RE IPOD. HOLD DOWN THE MIDDLE AND MENU BUTTON ON YOUR IPOD, GIVE IT 10 SECONDS, LET IT BREATHE AND THEN PROCEED TO HOOK IT UP TO YOUR ITUNES(RESTART YOUR ITUNES AS WELL)... VOILA IT SHOULD WORK AND SYNC...
Sep 01, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
169 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
