Question about Motorola Mobility C168 Cellular Phone
Battery not charging Drops calls
Do not get Battery Charged message
Calls are dropped soon after connection
Replaced battery
Posted on Mar 04, 2009
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Dropping calls as soon as they connect
remove battery and clean the battery terminals and contacts. Now insert the batttery and charge fully.
Once it is charged make a call to check. If the battery level is dropping the batttery can be faulty.
If not clean the set and test once again. If fault is present a harware issue can be a suspect.
Sep 11, 2010 | LG Neon GT365 Cell Phone
N73 mobile is Switching off after one or two calls & light sensor is bot blinking. Battery is full charged after listing two to three songs, mobile get Switched Off. when we connect to charge the...
The Happy news is your phone is perfectly working.Only the battery is the problem.Your Battery is stone dead.That is it will get charged(Acting like it is charging).If you use your mobile the charge will go off soon.Is you battery is bulged?See any slight bulge in the bodPlease do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-) y of the phone..Replace the battery soon...
Jul 28, 2010 | Nokia N73 Music Edition Smartphone
Short Battery life, Randomly shuts down, and more...
sounds like the battery is shot. Get a new battery and fully charge it. I try to charge my phone more off of a power outlet and not the cigarette lighter in a auto. The battery will last longer that way. something about cigarette lighters. As far as the messaging and failed calls goes. up grade your tower signals. contact your cell phone company and get the number for upgrading the towers.
May 24, 2009 | Pantech Duo Smartphone
Paired Blackberry Curve 8310 w/Range Rover 2005 drops calls
Ok, this isn't so much a solution as a work around.
As long as your phone is still holding the call (showing connected), once the Range Rover drops the call, hit the soft button that shows a picture of a green phone receiver....as if you were making a call. This will cause the Range Rover to reconnect the speakrs/mike to the phone, and you can continue your call in relative harmony.
I still haven't figured out how to get out of the jam when a second call comes in while you are still on the first....
Good Luck
prduck
Dec 10, 2008 | 2005 Land Rover Range Rover
Cell phone in water
WELL THE WIRES WHERE THE BATTERY CONNECTS UP WILL BE BROKEN (NO POWER GOING THROUGH THEM) SO INFORTUNATELY IT IS BROKEN !
May 12, 2007 | Samsung SGH-x475
Problem with Calls
if the phone is still under warranty go get a new one otherwise it sounds like a serious hardware problem!!!!
Feb 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility C168 Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
