Question about Bose LifeStyle 5 Series-III CD Shelf System
Switching on Bose Powered Speakers
My LS5 music centre was stolen, but I still have the powered speakers intact. Can I feed these from a non-Bose source so I can continue to use the speakers? My main question is what conditions need to be seen on the control lead in order to power up the system (Previously controlled from LS5 music centre) Any ideas? Thanks Richie
  • 1 more comment
  • rmack2 Mar 04, 2009
    I have tried this, and it worked on the old models, but it seems I need a signal to switch on the unit! There is a 5-pin DIN plug on the unit, and I still have the interconnecting lead which is DIN to 2xRCA and a 3pole 3.5mm TRS (Stereo Jack). Just connecting the RCA leads and applying signal doesn't seem to work.
  • rmack2 Mar 09, 2009
    Let me clarify! The system in question is a POWERED Bose Acoustimass 5. The sub contains amps for itself and the "cubes". This was part of a lifestyle music system, but the cd/radio unit was stolen.
    As I can't economically replace this unit, I want to hook up the pre-amp out from my hifi system so I can use the speakers.
    Just connecting the RCA plugs on the bose lead doesn't work, there is a mini 3-pole TRS jack which is the system control. MY QUESTION: What signal needs to be applied to this control lead in order to power the system up? Thanks R
    Please can you READ my question carefully!
    The system I'm referring to is POWERED!! Active!!! I.e. it has on-board power amps.
    Discussions about power ratings and impedances are only applicable to the PASSIVE AM5!
    I just want to know what the old bose CD/Radio unit sent down the control lead to turn on the sub/amplifiers!!
    Scholar:
  • 53 Answers
Yes. You can connect them to any a/v receiver. Just match the speakers up with the proper ports.
Posted on Mar 10, 2009
  • 15,935 Answers
Your amplified speakers need turn-on voltage signaling the amplifier to power up.
As you can see on page 11 of THIS MANUAL there is an integrated (proprietary) system control wire with the audio RCA wires cable. This is the lead that sends voltage to your speakers to turn on.
You will at the very minimum need this cable, then splice off the "system control" plug to attach it to a power supply in order for your Acoustimass Module to power on and power your speakers.
This should be a 12VDC turn on signal.
Purchasing a 5A or so 12V power supply will be approximately $150+... and will need to be turned on and off manually each time you want to use the speakers.
I would suggest purchasing a reciever with a built-in amplifier and bypassing the Acoustimass module and just using the speakers directly to the reciever's output terminals.
Bose plays nice with its own, but adapting and using select parts doesnt work too well.
Thanks for using FixYa!!
  • blueextc3221
    blueextc3221 Mar 10, 2009
    Additionally - some higher end recievers have a SYSTEM REMOTE terminal to turn on powered speakers. Look for that feature if purchasing a new reciever. Then they will turn on and off with the reciever and eliminate the need for a seperate power supply.
  • 55 Answers
If the speakers are self-amplified, you can hook them up to any source, if not they may not work on a source with a very low-power amplifier, but should work with any good amp+source. Hope that helps!
    Sergeant:
  • 320 Answers
You can get the connector between the bose system and tv as using this connector speacially made for this type of systems will automatically get detected to your system and tv as it is compitable for supporting to all types of units.just
click
www.radioshack.com
and clarify them exactly as what your unit is and to what you have to connect .by that i mean the exact model of your tv.and they will give you the proper connector for that.connect that connector to bose and the tv wire to the other end of the connector.this will automatically get detected.and you you can set the required setting on what you have to adjust.
Posted on Mar 09, 2009
  • 10,515 Answers
The best i can offer you is a manual...it might help you :-
http://products.bose.com/pdf/customer_service/owners/og_am6_10.pdf
Thanks.
  • 203 Answers
I have the bose acoustimass 5 sub box and surround speakers.
the ratings are - 10 - 200 watt / channel.
4 - 8 ohms.
any supply will do, you will find it hard to damage these babies!
Posted on Mar 04, 2009
  • sean sutton
    sean sutton Mar 04, 2009
    the new units use a remote lead to turn the signal on just like a car stereo turns on its amp for a sub box.
    you could possibly use a creative digital control pod for the job.
  • sean sutton
    or try this fella. i use him for my bose spare parts.
    http://www.warehousesound.co.uk/store/st...
  • Bose Master
  • 19,396 Answers
Bose connection speaker should have both the Bose multiple connector and the regular adio jack option, you just have to connect them using a regular audio jack cable.
Posted on Mar 03, 2009
  • 1 more comment
  • Ginko
    Ginko Mar 03, 2009
    You find some info on recovering broken Bose system here.
    Also do not forget that Bose speakers are active, as already suggested you need to connect to a preamp out, or you will risk to bloww them.
  • Ginko
    Ginko Mar 09, 2009
    When you use the speakers as stand alone you need to use the 3.5mm Stereo Jack to connect them.
  • Ginko
    Ginko Mar 10, 2009
    There is no data or control cable, active means that your speakers are amplified, not that they have a preamp inside or some device that can be regulated through a data or control cable.
    The only control is how much volume is sent to the speakers.
    The only cables to the speakers are either RCA or Jack, and they do the same thing.
    Speakers are not active, only acoustimass subwoover is active.
    The speakers are not active , and apart connecting the audio, either through RCA or the Jack (they do the same, no control cable.
    Bose speakers have bad performance if you do not have the bose subwoofer.
    To resume:
    If you have bose soobwofer ( acoustimass) do not connect it to a final , that is active and must get preamped system, also connect power to the system.
    If you have only speakers, sell them on ebay, they are not active and do not work well if not with an acoustimass system, this speakers are not the active computer speakers sold separately, what is active is the acoustimass.
    Here is acoustimass connection, only audio cables go to speakers, either RCA or Jack, such a thing as a control cable does not exist on speakers, even if active, and the speakers alone are not even active.
    Here regular connection to your system speakers, only a set of regular audio cable coming out from the acoustimass unit to speakers:
    See wiring diagram from manual:
    If you have the acoustimass main unit things are different, but if you have speakers only, they alone will just be bad speaker without a dedicate main unit, and they do not have any amp unit inside, just two audio connectors to the Bose technology cones.
    Hope this had clarified ideas, let me know if for some reason I am wrong about your system, if for example you have also the woofer unit.
    If this had been satisfactory, do not forget to accept the riught solution.
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi!
You can use it with a non-bose source aswell. However before doing that you need to check for the resistance(in ohms) and power ratings(in watts).
Please ask for further clarifications.
Thanks
Rylee
  • 10,594 Answers
If the speakers are independent units and has no power amp circuits inside then can be used with any power amplifier of same wattage.
Can you post speaker connection pins snap here?
    Top Expert:
  • Bose Master
  • 77,202 Answers
U can use the speakers on another system as long as u have a PRE-AMP OUTPUT on the amplifier u intend to use,
I have lost my sound from TV through the Bose Lifestyle 48 recently. All other sound sources work fine- DVD/CD, FM/AM.
Hello Sunny,
No TV model... came through with your
Bose LifeStyle home theater question...
I'm just going to mention that I have seen a couple of available configurations... depending on your signal source... BROADCAST, CABLE, SATELITE... (etc.)...
If it is Just your intention to source from the TV...
THERE (at the TV)...
It might be as simple as going into "menu" ... then move down to your "AUDIO" PROFILE.. and make sure your external speaker OPTION is showing "ON" (or "equipped")...
on your TV and making sure your PRIMARY volumes sources & destinations (Bose) volumes at acceptable levels... so as to not FRIGHTEN your neighborhood when the sound does come through)
No success ... comment me back with your TV signal source...
HMDI or optical outputs... (and does your AUDIO Work in STAND-ALONE on the TV... Now??)
If all else is working on the BOSE... I don't think we need to continue there...
Comment me back if you need... I'll be around!
Post comments... addendum
(I did say Menu... (twice))...
RESET , General:
**WARNING:
This operation will clear all of your customized settings.
V... depicts the volume down button on your remote
(immediately above the "menu" button).
With the set turned off...Stand in front of TV.
At the right side on the TV set... locate the power
button on the right side...
WHILE holding down the V (on the remote)
Turn on the TV POWER button on the TV.
(The TV will turn itself off, then back on again.)
Then ... V (symbol) Release the button.
**WARNING:
This operation will clear all of your customized settings...
I'll still be here... comment me back... if you need.
Hope it helps
ELSE ...
We need to move on to your PCBs
Jul 21, 2016 | Bose Lifestyle 48 System
Bose av18
Hum is tough. It is often caused by quite a variety of things. First, address the basics:
1. Make sure that none of your signal cables run near to power cabels.
2. If possible, feed all power from the same receptacle.
3. If your plugs are not polarized, try reversing one at a time.
If none of those basic checks uncovers your demon, verify the path of the noise by disconnecting the signal from the preamp at the input to the sub. If is still hums, then look closely at the power feed to the sub, More likely, the hum will stop (along with the music.) In this case, try breaking the shield ground at the sub input (e.g. with a ground isolation adapter.)
You should also confirm that the hum is limited to the sub. Subs tend to exaggerate hum because playing signals in the 60Hz is their forte. So with the sub turned off and bypassed, listen for the hum in your main speakers. If it is there, too, then start checking your sources. Remember, even a source device other than the one selected for play could be the source ... completely disconnect each source at the preamp to track it down.
Aug 03, 2014 | Bose Audio Players & Recorders
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
Need a power cord for a Bose Lifestyle Model 5 Music Center. Seriel #U288342.
that is a ac adaptor for the ls5 think it's a 12ac not dc output ,be careful. get one from bose.
Oct 09, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Audio problems with Bose 321 system
Hi, sounds like the centre front speaker is disconnected. Check the wiring on that, if all is good there then a fault most likely with the amp. To make sure try connecting a different speaker to the centre channel just for test purpose to eliminate a speaker/cable fault. Best of luck
Jul 11, 2009 | Bose 3·2·1 II System
Bose 901 mk11 no sound . i have checked all connections, swapped speakers over.
since that u swapped l/r speakers already,it might not be ur speakers,if u wanna make sure ur 901s are working,feed a 1.5 v battery power to ur speakers,,(device a connector,piece o wire ,etc) if the speakers makes ticking sound upon contact,u got continuity.now..ur eq..make sure it its working,,(see instruction manual)lastly..confirm that ur amp which is powering ur 901s is emitting sound.(hook up a different speaker)
Apr 14, 2009 | Bose 901 VI Main / Stereo Speaker
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Bose lifestyle 5
I cannot exactly solve this issue but I can make a comment based on investigation. Lots of people have this issue but there are very few comments to help solve the issue unfortunately.
I have the same issue and have been able eliminate various things because I have a second complete Bose Lifestyle 5 system.
It is clear the issue does not lie in the Sub and is related to the Music centre unit. I can use a second identical music centre to power my sub just fine and my broken Music centre cannot drive my second sub.
Now the issue is knowing where to track down R428 in the music centre which is the suggested fix to this issue. I have opened my unit and there are resistors various Resistors in the 400 range but no R428.
If anyone can help with the location of R428 in the Music Centre I would be very grateful.
Thanks,
Jeff
Nov 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Bose LifeStyle 5 Series-III CD Shelf System Logo
2,996 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
