Question about Sony Cyber-shot DSC-W30 Digital Camera
Zooming lens got stuck up
When switch on the camera the zomming lens got stuck up and plusating continusoly.After switch off also it is in the same condition.
  • 477 Answers
The lens need to be replaced and is failing I have new lenses in stock if you need more information go to www.digitalcamrepair.com.
Posted on Mar 02, 2009
S600 turns on with a beep but no screen, and zom stuck in out position.
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 03, 2010 | Samsung Cameras
Zom not working at all. zom error reads in window . While chanching batteries, zoom came out and stay out. When push the W/T button, camera wil go off. No photo action. TNX for help
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Feb 14, 2010 | Fuji FinePix E550 Digital Camera
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
In the screen says lens error
Hi I had the same problem with a codak C743. I cleaned the lens casing from out outside as much as I could and sprayed a tiny bit of WD40 making sure not to get it on the lens itself.
Then I kept turning it on, and zooming in and out until I got the lens error message, switched it off, the on again, wipe, new WD40, zoom etc. repeated this s number of times until the lens was freed.
I think I had some sand/ dirt around the casing.
Worth a try I guess.
Dec 20, 2008 | Casio Exilim EXS10BK Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Lens error No. 221,0,0,0
I have Pentex Optio E 30 camera
When i start my camera , i get error message Lens Error : 221,0,0,0
lens got stuck and it is not coming out for zooming
Sep 06, 2007 | Kodak EasyShare C703 Digital Camera
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Out of focus
Sounds like the camera is trying to focus if you hear sound when pressing the shutter halfway down or zooming. If the noise is a scraping or grinding sound, you might have debris stuck between the cracks of the lens and the camera body. This happened to me after i dropped my canon sd550 on the beach just once and it never recovered. Next to water sand has got to be one of a camera's worse enemy. Also, the lens might be cocked a bit which would prevent the camera from focusing and zooming smoothly. Try gently adjusting the the lens. Sometimes the slightest imperfection in the lens will throw everything off. Good luck!
Apr 11, 2007 | Kodak EasyShare Z760 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
123 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
