Question about Sony Ericsson K790i Cellular Phone
Ringtone not working
When i assign a ring tone for a particular phone number as distinct tone, the phone automatically uses the general ring tone instead of the tone which i have assigned for that caller.
do you have any solution? if yes than please suggest me what to do.
  • praveensh583 Mar 02, 2009
    i did a lot of time but the problem sill persist.
    i made the master reset also but it didn't worked
    Problem Solver:
  • 8 Answers
U need to go contacat list then
contact seting and then u get a option of image used as wel as ringtone used or assin tone then u can set specific tone for each number..
Posted on Mar 02, 2009
How Do i set a specific ringtone for just one of my contacts, but not as my default
go to that particular contact press option - assign ringtone , then select the ring tone you wish to assign
Nov 03, 2010 | Cell Phones
I dont find stored songs when i them for assigning ring tone to a particular number and assigning songs to alarms. I only find default songs stored on phone memory.
pls put songs in digital folder and ringtones in simple folder. dont change that again..now assign it..u wil get it right..!!
Jun 16, 2010 | Nokia N73 Cellular Phone
How do I assign ringtones to particular people? Thanks
select a particular contact,go to options and then select 'assign ring tone' and then assign the desired ringtones.
Dec 04, 2009 | LG Vu CU920 Cellular Phone
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Assingning a ring tone to a person
Go to contacts and select one. Then press options and edit contacts. Then move to the right and u will see picture and ringtone. Then u select ur ringtone.
Jun 23, 2009 | Sony Ericsson W760i Cellular Phone
Downloading a ringtone to my phone
in motorola v3 razr ringtones get downloaded in the phone memory and doesnot go to the card memory . so you need to switch the memory to the phone memory and then you will be able to see that ringtone. once you move that ringtone to the card memory and then you can assign the ringtone also .
If you want ot assign the ringtone to some particular contact then it should be in the phone memory then only it wil pick up that not from the card .
Mar 26, 2009 | Motorola Mobility RAZR V3
Ringtone problem
You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
1) First save the specific number
2) Select the ring tone
3) Assign the this ring tone for that number
This information help to you othere wise refer your phone user manuals
Jun 11, 2008 | LG VX8300 Cellular Phone
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Can only use 1 ringtone at a time on my Motorola v3.
Are your contacts off the SIM? You cannot assign a ringtone to a SIM contact that is different than your general ringtone. If it is a SIM contact save it to your phone then you should be able to assign a distinct ringtone.
Dec 22, 2007 | Motorola Mobility RAZR V3
Sony Ericsson K790i Cellular Phone Logo
96 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
