Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Not ABLE to switch on MC9090. tried replacing the battery . Held the power button for 2 mins . nothing is working. Is there any key combination to start the reader ? please help.
  • aas4mis May 11, 2010
    Start the reader? do you mean the scanner is not working? Might need to load DataWedge.
  • 12 Answers
I know it may be a little late now since you're question was a couple months ago, but I have had this problem with some 9090's before too where a warm boot (holding the power button down) will not bring them up, but a cold boot always does (unless of course it truly is defective - that's not usually the case though).
To do a cold boot, pop the battery out part of the way until it "catches" (you'll know what I mean if you have an MC9090 and try it). Then hold down the trigger and the power button simultaneously while pushing in the battery all the way. Once the battery has been pushed in, release the power button and the trigger.
This should cause the MC9090 to boot up fine. Make sure you release the trigger after doing the steps above. Sometimes people don't do that, and this causes the MC9090 to go into an infinite warm boot where it just continuously reboots over and over. The only way to get out of it is to cold boot again, but this time release the trigger in time.
Thanks,
Brad Radaker
Radicomm (makers of QuickTalk - push-to-talk over WLAN for the MC9090)
www.radicomm.com
Posted on May 13, 2009
  • 4 Answers
Dear Varsha,
No other combination, Your device need some service support.
Posted on Mar 02, 2009
My tablet froze it won't even let me put the password what can I do ?
Remove the battery.
Wait for 5 minutes.
Check your phone-sim and memory-sim is inserted correctly.
Replace the battery.
Try one of the following immediately after you turn on the power and while the power comes on...
  • Combination 1 - Volume Up + Camera button.
  • Combination 2 - Volume Down + Power button.
  • Combination 3 - Volume Up + Power button.
  • Combination 4 - Volume Up + Home + Power button.
  • Combination 5 - Volume Down + Volume Up + Power button.
  • Combination 6 - Home + Camera button.
  • Combination 7 - Home + Power button
Combination 2 has worked for me in the past, but it depends on your Tablet type and model.
Feb 24, 2015 | Samsung Galaxy S3
My viewsonic n2751w tv will not stop channeling down... have to put weight on top to stop
mmm sounds like a sticky channel switch on your tv itself. Spray some special stuff called Contact cleaner spray available at any electrical outlet or hobbyshop - its a little bit expensive but works great to clean motherboards and most other electrical equipment. Spray while the tv is off and press buttons in between sprays
Jan 14, 2015 | ViewSonic N2751W 27 in. LCD Television
92 plymouth voyager wont start and nothing work the windows wont go down the lock and unlock button does nothing idk what the problem is i had the battery tested and the battery is fine what would cause...
Nothing works? How about the headlights, do they work? If yes, then start checking all fuses in the Power Distribution Center or Box under the hood. If no, then look for a bad maxi-fuse in the PDC, and check for a bad fusible link between the battery and the PDC. The battery positive cable goes to the starter, but a pigtail lead off the positive would go to the PDC, to distribute power to all the various circuits on the car.
When you turn the key to on, does the dash light up? If yes, at least power is getting to, and going through the ignition switch. One could then check for power on the starter solenoid wire when key was held in crank or start position.
If nothing when turning key to on-no dash lights, nothing-then check for an ignition fuse in the PDC. If fuse is good check for power being available at the ignition switch connector. If no power there, check wiring between PDC and the ignition switch-if power is up to the switch, but nothing happens with key on, no dash or warning lights, then could have a bad ignition switch.
It just sounds like a maxi-fuse has blown, or a bad fusible link. Good luck.
Mar 18, 2013 | Cars & Trucks
Hi my MC9090-G wont power on.
On an MC9090, with the battery removed, hold both power and trigger down, then insert the battery, and keep holding both buttons down. Wait for the onscreen display.
Feb 28, 2013 | Symbol MC9090-G RFID Handheld Barcode...
When I press the keys on my MC9090 they give the wrong output.
The Motorola MC9090 can have different keypads attached. If you do change the keypad for any reason for example go from a 53 key to 43 key layout the terminals must be cold booted.
To cold boot an MC9090 running Windows Mobile 5. Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the device is still not giving the correct key output it may have a faulty keypad.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 11, 2012 | Zebra MC9090-G Barcode Scanner
The letter I key does not work. Everything else
If your I button is not working then you should try this;
1. Switch off your hand held and take off the battery, then place the battery back on.
2. Switch in your hand held and try the button.
If this fails to work then you can proceed to take your hand held to a certified blackberry service shop within your area.
Kind Regards
Jan 26, 2010 | RIM BlackBerry Bold 9000 Smartphone
Combination/ Headlight switch
disconnect battery and block wheels lower tilt wheel and un thread tilt release handle remove screws that hold lower colum cover on and remove cover you will have to remove the panel above the pedals if it has one top colum cover is only held on by key tumbler to get tumbler out turn key to run postion and press in the silver button on the bottom of the housing and use key to remove the tumbler once tumbler is out shift to 1 and tae cover off remove 2 tork screws holding switch on and disconnect connectors reverse order for installation let me know how you make out
May 21, 2009 | 1997 Ford Expedition
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
3,052 people viewed this question
Top Zebra Computers & Internet Experts
Mike
 steve
steve
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
