Question about Canon PIXMA MP470 All-in-One Printer
Ink How does one get the ink off their fingers?
    President:
  • 1,073 Answers
Wash them in alcohol
Nic
Posted on Mar 02, 2009
Error code 09,037.45:210259
Ink cube count sensor flag is stuck. 09,37.45 would be the yellow. Make sure you are using genuine Xerox OEM ink cubes.
Features on the bottom of the genuine ink sticks actuate the Ink Out Sensor in each ink channel in the Ink Loader. Damaged ink, or non-genuine ink may not reliably actuate the sensors.
If the sensor finger is not stuck down, then the Ink Loader will need replaced. After replacement you will need to run the "Clear ISC Fault" test to clear this error.
133K27710 Ink Loader Assy & Door. (8500/8550)
Jan 31, 2014 | Xerox Phaser 8500/DN Printer
How do I replace the ink cartridge?
Replacing the Ink Roller
1. Press OFF.
2. Remove the printer compartment cover.
3. Remove the ink roller from the right side of the compartment. Insert your
index finger, nail down, under the tab on top of the ink roller. Gently lift the
ink roller out of the compartment.
4. Lower the new ink roller (IR-21) into the compartment and align the hole
in the ink roller with the pin in the compartment. Press down until it snaps into place.
5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
Feb 04, 2011 | Texas Instruments TI-5006 II Calculator
Xerox Phaser 8560 Printer Error 09,036.44:9235
Hey, if after following Prefabs advice, and the ink is xerox brand, and not broken you should replace the ink loader, part number for the 8560 is 133K27771. Here is a video that shows you how.
Jan 14, 2011 | Xerox Phaser 8500/DN Printer
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
Xerox system error 09,035,43:46300.
This is from the service manual
Harry
9,035.43 through 9,038 (8500/8550/8560 only):
Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Troubleshooting Procedure for Ink Loader
Step Questions and Actions Yes No
Is the ink Genuine Xerox? Are they the
correct sticks for the model?
Go to Step 2. 1. Advise customer.
2. Replace the Ink
with Xerox Ink.
3. Run Clear ISC
Fault
test to clear
the error. The
Clear ISC Fault is
located in the
Internal
Diagnostics
Function menu.
2 Manually verify that the ink stick is able
to advance in the ink loader chute.
Check for broken or wrong type ink
sticks.
Go to Step 3. 1. Remove any
blockage and/or
replace the ink
stick.
2. Replace the Ink
Loader.
3. Run Clear ISC
Fault
test to clear
the error
Feb 25, 2010 | Xerox Phaser 8560MFP Laser Printer
There's Not Enough Ink on the Drum, Wants me to add more
your ink fingers may need cleaning or replaced. your ink pump may be worn out. you should call a tech
Sep 21, 2009 | Gestetner Copier
Printerhead is not installed.
What you will need to keep in mind is that the ink cartridge contains liquid ink, once opened, can and will evaporate. First, wash you hands with soap and water to remove excess finger/hand oils. Use a clean, moist, paper towel, make sure you ring out the excess water from the paper towel before you begin. Remove cartridge, gently wipe the towel over the contact's pad, and the nozzel tip. Use a dry towel, and patt dry, reinstall. and run an alignment pattern test.
Note: If you do not see an ink trail on the paper towel, The Ink has dried up, and you will need to but a new cartridge.
Note: do not touch the Cartridge GOLD contacts, with your fingers, finger OIL will clog the jet pours, and cause them to corrode.
May 07, 2009 | Canon PIXMA MP610 InkJet Printer
Canon IPF 8000 does not recognize ink tank
thre was a part of inks that didn't worked....so there is no problem of the machine but problem of the chip
Apr 15, 2009 | Canon imagePROGRAF iPF8000 Printer
Xerox 8560 Error 09.037.45:8982
Don't believe any of the misinformation about Xerox 8560 , 8570 , 8870 inks not loading or being rejected at the at the ink loader gateway. There is a very simple solution to getting the printer to accept any and all ink no matter if it is from another region or starter pack. There is a plastic pin that pops up at the bottom of the ink loader when you begin to drop or place the ink down into it - you can easily circumvent this. If/When the pin pops up (or it just stays up), you us a small magnet and place it down the right side of the loader (move it back and forth until you find the sweetspot) and you will hear a loud click and the pin for that specific loader will release and drop down. Now here is the trick-before the pin pops up again, use your finger from your other hand to hold the pin down, then use your other hand (as the magnet is no longer needed because your holding the pin down) and grab the appropriate ink cube and quickly place it in the loader while pulling your finger out and slide it down the channel . The pin usually moves up very slowly giving enough time to do this-if it doesn't, just repeat the process. Or instead of using your finger to hold the pin down, get a pencil with eraser on the end or small spatula (something thin enough) so you can hold the pin down from within the channel-way. That way nothing(meaning your finger) will get in the way of putting the ink cube into the loading space.
Never believe what the manufacturer tells you-I've been doing this with my 8570 and have no problems.
May 30, 2008 | Xerox Phaser 8560DN Laser Printer
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Canon PIXMA MP470 All-in-One Printer Logo
21 people viewed this question
old marine
old marine
