Question about HP Photosmart C7280 Laser Printer
Ink system failure unable to copy 0xc05d0281 - HP Photosmart C7280 Laser Printer
  • Christine Wimmer-Milakis
    Also mine will say unable to copy, print and fax. Error: 0xc5d0381. I turned it on one day and this came up. The printer is less than 3 months old. Can someone help?
    Sniper:
  • 54 Answers
Follow the steps carefully from the front panel of the All-in-One.
1. Get the unit into the “Support Menu” by following the steps given below.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Now Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Now the Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11.Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Sep 12, 2009
  • 4,041 Answers
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
    Scholar:
  • 169 Answers
You can try a reset on the printer using the # and the number 6,holding them down
while plugging in the power cord at the back of the printer.if it still does not work
then you can try the same with the # and the number 9.If it still does not work,get
your printer serviced.
Posted on Jun 25, 2009
5 Suggested Answers
Scott Ellin
  • 558 Answers
SOURCE: ink system failure
There may be some conflict arised in Printer, and you need to reinstall it again:
Uninstall the HP Printer software by using the Add/Remove Programs tool in Control Panel. The HP software will includes:
By Printer Design Home
HP Print creator
HP assistance
HP Instant Delivery
HP Print Screen Utilities
HP Photo and Imaging software
2. Uninstall the printer driver from the device manager.
Please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Then install the HP printer software, when it ask to connect the printer, then only connect and power on.
Your PC will automatically accept this USB Hardware driver.
After doing above steps please reboot your PC finally and Printer
Visit the Official Web site of HP for your Printer driver and other useful information using this link:
HP Printer C6180
Let me know the result, so I can further investigate the problem.
Best of Luck & Have a Nice Day.
Ellin
Posted on Oct 06, 2008
SOURCE: My HP 3310 shows: Ink
Try reseting your printer.
There are some additional resetting steps in this document ...click here
Posted on Feb 11, 2011
  • 159 Answers
SOURCE: HP Photosmart All-in -One Ink
You should try to reset your printer, click the link to see how and find other tips:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=439491&tmp_track_link=ot_search
Posted on Jun 05, 2011
reyjoshua07
  • 1157 Answers
SOURCE: HP printer Ink system has
Hi charlie1929,
Please follow these steps and solutions to resolve the issue.
Reset the printer
  • . The error message might disappear after you turn off the printer and then turn it on again. After you make any adjustments to the cartridges or the printhead, reset the printer in order for the error message to clear completely. Follow these steps to reset the printer.
1. Press the Power button to turn on the product.
2. With the product turned on , disconnect the power cord from the rear of the product.
3. Unplug the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Plug the power cord back into the wall outlet.
6. Reconnect the power cord to the rear of the product.
7. If the product does not turn on by itself, press the Power button to turn it on.
  • . If these steps resolved the issue , you do not need to continue troubleshooting.
  • . If the issue persists , continue to the next solution.
Remove, clean, and reinstall the Printhead
  • Remove the printhead
2. Open the cartridge access door.
3. To remove each cartridge, press the tab on the front of the cartridge to release it and remove it from the slot.
NOTE: Do not leave the cartridges outside the product longer than 30 minutes. Doing so can result in damage to both the product and the cartridges.
4. Lift the latch handle on the carriage until it stops.
5. Lift the printhead straight up to remove it.
Clean the Printhead
  • . There are three areas of the printhead that need to be cleaned: the plastic ramps on both sides of the ink nozzles, the edge between the ink nozzles and the electrical contacts, and the electrical contacts. Follow these steps to clean the printhead.
CAUTION: Do not touch the ink nozzles. Do not touch the electrical contacts with your finger. Use only cleaning materials to touch the electrical contact areas.
1. Gather the following cleaning materials:
  • . Several clean, lint-free cloths or papers. Coffee filters and glass-cleaning cloths work well.
  • . Distilled or bottled water. Do not use tap water, because it can contain contaminants that can damage the printhead.
2. Lightly dampen a clean, lint-free cloth.
3. Use the damp cloth to wipe the electrical contacts from the bottom to the top. Do not go past the edge between the electrical contacts and the ink nozzles. Repeat this motion until no ink remains on the electrical contacts.
4. Use a fresh, lightly dampened, lint-free cloth to wipe any accumulated ink and debris from the edge between the ink nozzles and the electrical contacts.
5. Use a fresh, lightly dampened, lint-free cloth to wipe the plastic ramps on both sides of the ink nozzles. Wipe away from the nozzles only.
6. Dry the previously cleaned areas with a clean, dry, lint-free cloth before proceeding to the next step.
7. Lightly dampen a fresh, clean, lint-free cloth with bottled or distilled water.
8. Clean the electrical contacts inside the product by wiping them from top to bottom. Repeat this motion until no ink remains on the electrical contacts.
9. Dry the area with a clean, dry, lint-free cloth.
Reinstall the printhead
1. Raise the latch handle, and then reinsert the printhead.
2. Carefully lower the latch handle before reinserting the cartridges.
NOTE: Leaving the latch handle raised can result in incorrectly seated cartridges and printing issues. The latch must remain down to install the cartridges correctly.
3. Using the colored shape icons for help, slide the cartridges into their appropriate slots until they snap firmly into place in the slot.
4. Close the cartridge access door.
If the previous solutions did not resolve the issue, replace the printhead. Contact HP support to obtain a replacement printhead.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 21, 2011
How do i fix error code 0xc05d0281
http://h30434.www3.hp.com/t5/Other-Printing-Questions/0xc05d0281-error/td-p/615959
Sep 01, 2014 | HP Photosmart C6180 All-in-One Color...
Error code 0xc05d0281 how do i fix this
If you have installed generic print cartridges, that could be your problem. I used to use an HP printer and after an update from HP to the printer I found that it was impossible to use the generic carts. HP had somehow electronically blocked the use of generics on the printer. It sits idle in my basement now because I refuse to pay their exorbitant prices for ink.
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
Refer to printer documentation
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
Have a HP3310 all in one and keep getting error 0xc05d0281 Ink system failed??? can anyone help??
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 05, 2011 | HP Office Equipment & Supplies
HP photosmart C7280 ink system failure 0xc05d0281
Go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&rule=11380&product=1153494&key=null
Nov 04, 2010 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Ink system failure
HP Print creator
HP assistance
HP Instant Delivery
HP Printer C6180
Ellin
Oct 03, 2008 | HP Photosmart C5180 All-In-One InkJet...
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
Open the printer as if to replace an ink cartridge. On the print head there is a black plastic arm about 2 inches long. Re-connect this with the white cog wheel so that the protruding part is in the center of the black arm. Close lid, power on and job done.
May 07, 2008 | HP Photosmart 3310 Printer
HP Photosmart C7280 Laser Printer Logo
1,868 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
