Question about Whirlpool AWM5125/1 Front Load Washer
Machine cannot switch on
When we switch on the power supply, all the lights will light up for 1 second then go off by itself
  • 82 Answers
I have a whirlpool machine here now that I have just repaired. It sounds like the main control (like a small computer) has failed. Requires a new control unit.
Sorry but hope this answers your question
Regards jb
Posted on May 12, 2009
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds
The motor controller board has a switch mode power supply problem.
Best to get a new motor controller board Or a technician to look at it.
Look at the 6 digit part number under the bar code to get the right part for your machine.
Nov 22, 2013 | Fisher Paykel Eco IWL16
Light turns on by itself
Sometimes they just need to be reset
1 turn off power to switch (Circuit Breaker off)
2 wait 30 seconds
3 re - turn on power to switch again (Circuit Breaker on)
4 wait for lights to turn on by themselves ( about 15 seconds after power is turned back on)
should be OK after this remember to not enter the beam after power is turned on ...... (see #4 above) as this would make switch beam super sensitive. Hope this helps
Apr 01, 2013 | Leviton ODS10-ID Decora Wall Switch...
When pressing start button the machine starts but only runs for 1 second. the led lights up the message (turn on power supply)
this souinde like your power suply switch is turned off. if you look on the back of your computer were the power cord goes into the computer thats your power suply. if you look closly there is a switch on there this switch proble got shut off. you wanna make sure it is turned on.
Jan 07, 2011 | HP Compaq Evo Workstation W8000...
Hi, my HP Pavillion a1240n won't start up... the wall plugs work and the power supply is plugged in but no lights are showing. I've also been flipping the switch beside the power supply at the back, and...
There are only certain items that will not power up a machine. 1. The power supply itself could be gone. 2. Check your ram. 3. Your hard drive. In most cases it is the power supply. Take out the power supply from the machine and plug it in to a wall socket. If it starts that it is not the power supply. If it doesn't start replace the power supply.
Dec 05, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
I am looking for a wiring diagram for my emachine front power switch
Power Supply Types
There are two basic types of power supplies. There are AT power supplies, which are older and in older computers, and ATX power supplies, which you will find in virtually every new computer you can buy.
There are two fundamental differences between AT and ATX power supplies. First, the switch mechanism is different. AT power supplies use a normal on-off switch, which directly turns the power supply on or off.
ATX power supplies use a momentary switch which does not directly control the power. Instead, the switch signals the motherboard, which performs one of three actions:
  • If the computer is off, the power supply is turned on (which turns the computer on)
  • If the computer is on, the computer goes into power-saving mode (standby)
  • If the switch is held for more than 4 seconds, the power is cut and the computer turns off.
Because of this difference, ATX power supplies are better for projects that require the second power supply to turn on automatically when the computer is turned on.
The second difference is in the motherboard connector: AT power supplies provide two 6-pin connectors (figure 1), which are easy to insert backwards. The ATX connector is a single 20-pin connector that only plugs in one way (figure 2).
Figures 1 and 2: The difference between AT (left) and ATX (right) motherboard connectors.
Both power supplies provide two types connectors for plugging devices into. These connectors are called Molex connectors, and they come in two sizes (see figure 3 and 4). A power supply will generally have a few of each size.
Figures 3 and 4: Large (left) and small (right) Molex connectors.
There is no difference between the two sizes other than the size itself. Both sizes provide the same amount of power to whatever device is plugged into it (12V and 5V). The small Molex connectors are generally used only for floppy drives. Large Molex connectors power hard drives, CD/DVD drives, and many fans and lights as well.
Note: You can purchase large and small Y-adapters if you run out of Molex connectors. Be careful when using the Y-adapters however, because if your power supply does not have enough power for all the devices attached (especially true for older, lower-wattage supplies), you can damage it.
Dec 03, 2009 | E-Machines eMachines Desktop PC
E-machine 5220 power up
Emachines have notoriously cheap power supplies. Often, while the power supply itself doesn't fail, it causes the failure of motherboard components, essentially trashing the computer.
Try the following:
First check and make absolutely certain that the power switch connector is properly connected to the motherboard. (Take standard grounding/safety precautions: wear a properly-grounded grounding strap, for example, when working with any internal components.)
Obtain a known-good power supply of equal or greater capacity to your eMachines PS and switch 'em out.
If either of these fixes your problem, well and good. If not, the problem may be, as is all too common with eMachines power issues, a motherboard issue caused by the power supply.
Jul 16, 2008 | E-Machines eMachines Desktop PC
Medion AE19E1 (second hand)
sir,,i think theres something wrong with the power supply,,,kindly checkthe power supply of it,,,thanks and hope to help you thnkss??
Jan 28, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Loewe Aconda 9381 HD/DR+ Will not switch
Could be loss of voltage on secondary or problem on Power supply. Check 4/5 (depnding on chassis) wickman fuses on secondary if none are o/c then replace power supply components with Kit from Loewe. Part number 90415.900.
Should take tv engineer about 1 hour (max) to replace parts form kit.
Aug 08, 2007 | Loewe ARC332 32" TV
Whirlpool AWM5125/1 Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
