Question about Ricoh Aficio 450 Copier
Hw many grams dv is needed in afficio 450 or gestetner 3245
Plz help hw many grams is needed in afficio 450 or gestetner 3245... plz the corect amount
  • 4 more comments
  • thraser
    thraser Mar 03, 2009
    i used original developer rico type 5
  • thraser
    yup its 500g. i put it all in dv unit after i cleaned it up...the 100 -200 copies is good after dat its starting to faded at the left side if ur facing the output copy.... i olridy try to run 2805,2801,3001,...wen i check the dv unit on its magnet the dv just stay in the right side if in the right side ur holding is wer the toner is loaded..
  • thraser
    i run 2801 and the result is very low (.56)... and the 3001 result is (170) i olridy try diz many times but the copy is faded at da left side if ur facing the output copy....
  • thraser
    i run many the 2805,2801,3001, wat will be da disadvantage of diz it will reduce the life span of my dv. ??
  • thraser
    thraser Mar 05, 2009
    hi ....my id output display VSG (4.11) VSP (0.00) VSDP (0.00)....wat is VSDP means??
  • jpd8 May 11, 2010
    1 bag of dev. material - $ around 30.00
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Posted on Mar 02, 2009
  • Anonymous Mar 03, 2009
    If that's true. Then you should know it is 500g. It says right on the bag
    So, if you were to take out the developer unit and tilt it to one side, the developer will fill in the empty spot on the roller, and then you can make some copies before it sort of works itself clean and fades away on one side? Am I understanding you properly?
    If that's the case, the only thing I can suggest is that the machine must not be level? I have never had a problem like that otherwise.
I dont know my user code for gestetner 3245 aficio printer
Hello!
Try to call your IT. He can log in to the machine and look in the Address Book.
See you
Oct 08, 2011 | Ricoh Aficio 450 Copier
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3245 dev.bias setting....
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Jul 01, 2009 | Gestetner Office Equipment & Supplies
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
