Question about Konica Minolta bizhub 180 All-In-One Printer
When I try to scan a document to my email the machine comes up with 'cannot connect to SMTP' message. How do I solve this????
  • 1 more comment
  • barnabash Mar 02, 2009
    thanks very much - awaiting further instructions
    my machine is a bizhub 210 - the message appears on the machine
    Thank you very much - the manual was a great help. I will obtain the ip details from our network administrator tomorrow. Much appreciated.
  • Konica Minolta Master
  • 13,433 Answers
The outgoing service SMTP settings are incorrect or the service is not functioning right now.
I recommend to double check your outgoing mail settings and also who is your email provider? I will get you the settings you need to use so we can get it to work.
Posted on Mar 02, 2009
  • Ekse Mar 02, 2009
    First lets check a few things:
    You get the error message on device and not on your computer screen?
    is bizhub 180 the model you have there?
  • Ekse Mar 02, 2009
    The scanner requires a smtp service to be present in the LAN - NETWORK it is connected to.
    The scanner alone isn't able to send emails.
    Everything has to go through a email server (smtp server).
    Here is the full user manual which covers everything about the network functions of this device
    http://kmbs.konicaminolta.us/productsatt...
    (if you are unable to open the manual right click on it and select save as, save it to your desktop or a place you will find it. Then install a pdf reader -free download here http://www.foxitsoftware.com/pdf/rd_intr..., after the software is installed open the manual again and it should work fine)
    You will need to get the smtp server ip address (and many other small details) from your network administrator or the guy who manages the network.
    If you don't have a smtp server the email scanning function wont work at all.
    how to open and edit the smtp/email settings on the device are covered in page 3-16 (chapter 3 page 16).
    all the details you need on setting it up are there, then you will just need to contact the administrator or network management in your company or someone who knows those things.
    ones you have the proper details use the manual to enter the correct settings or have them do it.
    Let me know if you need anything else.
    Thanks,
    Ekse
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Apr 01, 2009 | Brother MFC 6490CW InkJet Printer
Can't email doc from my panasonic copier dp2330
smtp settings? They are readily available in your email account settings in Outlook, or outlook express, whatever you use. You should just need to put in all of the pertinent email settings like smtp, pop, user name , password, DNS, etc. Not being familair at all with this machine. I might just suggest that if your outgoing email requires authentication, that is, sometimes a conflict that cannot be overcome with some scan to email machines.
Feb 25, 2009 | Panasonic Office Equipment & Supplies
Ricoh MPC 2500 won't scan?
do you have a smtp server? check the smtp server in the usertools, systemsettings, file transfer and smtp server
Jan 07, 2009 | Konica Minolta bizhub C250 All-In-One...
I want to scan and email a document from my new HP DESKJET F4280 printer. I can scan it, and then I try to share it, but when I hit the send button it says there is no internet connection. Am I right in...
When you scan a document it must be scanned with OCR software. The default scanning method will scan a document as a picture, not a document with letters and words. The OCR software will recognize the letters and put the scanned document in the proper format to open it with MS Word. The software that you scan with should have a setting for OCR, read your instructions or help files to get the details if you can not find them very easy in the software you use for scanning. .
The problem with using Outlook may be that you have not set it up properly to get your emails from your email server. You do not need to use Outlook or Outlook express to send any documents, you can use your web based email server if you like, but you can use Outlook Express as well. You just need to add the document to send as an attachment to the email.
To set up Outlook Express to get your email, you must first find out what the POP3 and SMTP setting you must use. You can get that information from your email provider, it is different for every email provider. Then you go to the "File" menu at the top left of Outlook Express and select "Identities" and select "Add New Identity" and from there you will go thru a wizard to guide you thru the process of setting up your email client. Just make sure you have the POP3 and SMTP settings available for you to put into Outlook Express when prompted to in the wizard.
Dave
Nov 13, 2008 | HP Computers & Internet
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Konica Minolta bizhub 180 All-In-One Printer Logo
50 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
