Question about Mitac Mio P550 GPS Receiver
MIO p550 will not turn on
My MIO P550 will not turn on. I checked the batteries - I have two - both have a voltage one has 3.7v DC and the other 4.15 volts. I am using the original battery of 3.7V.
Any ideas whats wrong?
  • 2 more comments
  • kgrant54 Apr 06, 2009
    Hi All,
    The Mio P550 uses a push button to power up or shut down. The unit is fully charged. I have pushed the "on" button and have also tried the hard reset (pushing the on/off button as well as pushing the hard reset simultaneously). It still does not turn on.
  • kgrant54 Apr 11, 2009
    Hi Gery
    Thanks for this potential solution. I tried your method several times with no luck in the unit powering on. I appreciate you taking the time to offer a solution.
    I guess I will have to send it to the repair depot for this Mio P550 - I imagine that the repair bill will be expensive
  • Gery
    Gery May 11, 2010
    it might be a problem on the mainboard of you P550.
    what happens when you connect the device to power charge and slide the on/off button from left to right?
  • gerry bissi May 11, 2010
    check to see if the on/off switch is on as well as the push butto. My c230 has 2.
    otherwise call Mio, they can help you.
  • 58 Answers
i think you must know the difference between hard and soft reset.
soft reset is the small hole you put the edge of your stylus to reset the device without erasing anything. (software restart)
hard reset (hardware restore) is:
switch the on/off slider button to OFF. keep the joystik pushed UP and without leaving the joystick slide the from OFF to ON and wait about 30 seconds.
do all that while connected to the power charge. I'd prefer you do that with a wall charger, and not with a USB cable connected to your computer (we dont like this charging state from USB ports)
let me know what happened after that. if possible, upload a video showing us what you did.
Posted on Apr 07, 2009
I formatted my p550 and I don't know how to bootup or reinstall the O/S
You'll need to find the firmware (ROM) image file (Google) and then: Connect the mio p550 to PC
1.put the Button of the PDA in ON position
2. hold the joystick downward and press the reset button
3.choose "Image Upgrade tools"
4.choose "0=Image by USB"
5.intall the usb driver (PC require the drivers). The driver in the
folder "USB driver" the software "dnw5.0e"
7.(if you want to make a test of connection USB, click the" USB
port/Statute". If all is ok go to step 8
8. click "USB port/transmitted" and to show the way of the file
"MioP550 - Osc260A R05_P09.nb0" the reset button to restart the mio p550.
Feb 22, 2010 | Mitac Mio P550 GPS Receiver
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
Dec 05, 2007 | Mitac Mio P550 GPS Receiver
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
Can't put Mio P560 in bootloader mode
up arrow + power_on until MIO logo
Feb 07, 2010 | Mitac Mio P550 Pocket PC
I have a Mio P550 Digi walker. How do you open the battery chamber in order to change the battery? Many thanks
I removed the rubber infill that covered a hidden screw. Released screw and then removed back plate. Removing the battery then required care as it is stuck with two sided tape to the Mio internals. Here I used a knive to prise/cut free.
Sep 14, 2009 | Mitac Mio P550 Pocket PC
How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mio p550 not recocnized sd cards
Try this : Open your device ( it have 5 screws). Inside next to the sd card reader are two metallic sponges. Take them off ( they are glued on some electronic parts and it's shorting the circuits)
Mar 13, 2009 | Mitac Mio P550 GPS Receiver
Mio p550 wireless N security connectivity problem
Had the same issue with my Mio P550's using an Airlink680W Wireless N Router and security mode WPA-PSK, TKIP & Password. I had to disable "Block WAN Ping" on the firewall and life is good.
Oct 03, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 reboots but does not take any touchscreen inputs
I had the same and contacted MIO (use the phone number for your country,
). It was related to the shock the screen got and they graciously changed it for me (it was during the second year of the warranty). If the warranty has expired, you are probably looking to about a hundred bucks expense.
Jul 02, 2008 | Mitac Mio P550 GPS Receiver
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
Mitac Mio  P550 GPS Receiver Logo
699 people viewed this question
Top Mitac GPS Experts
Greg Cann
Greg Cann
TO Lady
Are you a Mitac GPS Expert? Answer questions, earn points and help others
