plz help i nid the corect procedure hw to calibrate my copier afficio 450 or gestetner 3245...the developer and toner...
Comments:
Mar 03, 2009
- i run 2801 and the result is very low (.56)... and the 3001 result is (170) i olridy try diz many times but the copy is faded starting in the right side of dv unit...the developer is just staying in the left side wer the toner is droping....
Mar 05, 2009
- hi ....my id output display VSG (4.11) VSP (0.00) VSDP (0.00)....wat is VSDP means??
1. Check that Dev. unit has the lastest seals. 2. replace dev. material. 3. Dump dev. 4. add new dev. material. 5. Hand rotate the dev. unit 10 times. 6. reinstall the dev. unit into machine. 7. cover the toner inlet opening with a piece of paper 8. insert PCU unit. 9. turn the machine on. 10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times) 11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK. 12. Perform SP-3001 -- ID sensor initial setting. 13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU. 14. reinstall the PCU. 15. Run test copies.
Error C020 is coming up intermittantly.Applied test 03-112 (developer motor)it worked fine. Any...
(More)
Error C020 is coming up intermittantly.Applied test 03-112 (developer motor)it worked fine. Any ideas ? thanks
projector comes on for about a couple of minutes then it shuts itself off. Where can I go to have...
(More)
projector comes on for about a couple of minutes then it shuts itself off. Where can I go to have it looked at? I live in Arlington, Texas.
