Question about Refrigerators
The fridge section of my kelvenator fridge does not keep cool.
The temp does not go down past 22degs c. the freeezer section is working fine..
  • 400 Answers
I beleive that your fridge is short of refrigerant, it probably has a leak which needs repairing and then to be recharged.
Posted on Mar 05, 2009
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
My Model #gts22wcp fridge stopped getting cold. freeezer works great. Only blows cold air into fridge if freezer door is open.
Possibly a problem with the defrost system. If the cooling coils behind the freezer wall start to build up too much frost or snow, the air flow to the refrigerator section gets blocked first. So the freezer still works but the fresh food section starts to get warm . As the frost continues to build up, in time the freezer section will only get as cold as the fresh food section should. There are 3 main parts to the defrost system. You could have a burned out defrost heater, a bad defrost timer, or a bad defrost termination thermostat. The heater is located directly under the cooling coils in the freezer. The termination thermostat is a silver round disk clipped to the top of the same cooling coils, and the timer in located in the control panel in the fresh food section.
Apr 02, 2016 | GE Refrigerators
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Freezer works fine, but fridge is not cooling very well at all. I turned freezer temp down and fridge temp colder but nothing seems to be changing. It is a small 5ft. tall top freezer model.
Check to see if you have airflow in the freezer and that it is also blowing into the fridge section. Also, check to see if you see any ice buildup on and behind the back wall of the freezer. Post back to me here.
Jul 20, 2011 | Whirlpool Refrigerators
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Feb 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
