Question about Acer AL1916W 19" LCD Monitor
After loading windows Vista screen says no signal
I have an acer AL1916W monitor when I turn the computer on it loads windows then screen goes black with the message no signal
Why does it do this? any help would be appreciated.
Steve.
  • zenoah Mar 08, 2009
    I have fixed the problem by taking out the dmi lead and using std one
  • 146 Answers
Steve, i dont think there is any problem with monitor. restart ur pc in safe mode, change resolution to 1440X900.
Posted on Mar 07, 2009
No signal from computer after Windows XP loading screen comes up: when I turn the computer on, there's video signal to the monitor, but once it gets to Windows loading, it stops and goes black.
Does it do the same when you bootup in safe mode (hit f8 key while booting up)? if it is OK in safe mode, then it is software problem, not hardware.
Post back what you find.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Acer X233H 23" Monitor
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
Hello i just installed my chimei 19" lcd to my hard drive and i have connected it all up right it all loads up but when my screen comes on the little button on screen goes from green to red and says no...
Most probably your monitor has two inputs, one digital and one analog. Using the monitor's on screen menu select the other input and you should see your picture.
Dec 18, 2009 | Acer AL1916W 19" LCD Monitor
I plug the acer monitor in and then it works for 6 sec and turns black
What are you plugin the Acer Monitor into? Is your PC on? Do you have to load drivers? Did you turn your PC off then turn it back on so that Windows can detect the type of monitor?
Sep 17, 2009 | Acer AL1916W 19" LCD Monitor
Acer lcd monitor ''no signal''
It is screen resolution problem.
when you power up the computer press F8 key thene nter in enable vga mode then go to diaply property and set screnn resolution to 1024*768 thenh apply and ok.
Jul 12, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
