Question about Ricoh Aficio AP3800C Laser Printer
Function sc:552 problem RICOH AFICIO 2018d
Our Ricoh Afifico 2018d is showing error code sc552 can any one tell me what this is or how to fix it.
    Sniper:
  • 86 Answers
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
    Problem Solver:
  • 13 Answers
Go into sp mode as indicated above... select copy sp, go to number 5 which is mode.... select 810 sc reset.... then hold down photo/text mode and then #... machine will beep 5 times and start working.........
Posted on Mar 09, 2009
    New Friend:
My Ricoh Afifico Ricoh Aficio 2027 All-In-One is showing error code sc552 can any one tell me what this is or how to fix it
Posted on Jan 14, 2014
    New Friend:
This error is belongs to copiers heater unit 1. thrmister
2 open heater lamp circuits mostly it has been clear by changing thermister u can try dis may b u will succeed
Posted on Jul 20, 2014
Ricoh 2018D error code sc 552
Do following steps
1. Yellow cancel
2. 107
3. Hold down red clear/cancel
Machine will beep.
Select 1 - copier sp
Type 5# 810# (fuser sc reset)
Select execute and restart the machine.
If code re-appears you have a faulty fuser lamp or thermostat.
If machine works for a while or at least tries to warm up, you have a faulty thermistor.
Feb 06, 2018 | Ricoh Office Equipment & Supplies
RICOH AFICIO SP C811DN
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Sc552
SC-552 Fusing temperature warm-up error
The fusing temperature rises less than
7 degrees in 2 seconds, and this
continues 5 times consecutively.
The fusing temperature is not detected
in 25 or 35 seconds.
Possible Cause:
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Power supply board defective
Aug 05, 2011 | Ricoh Aficio 2015 Copier
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Printer side problem
Try by switching off and on the machine.
If every time you switch on the machine, SC824 re-appears, please replace the NVRAM on the controller board or the controller board itself.
Nov 17, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio AP3800C Laser Printer Logo
10,180 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
