Question about Nikon D200 Digital Camera with 18-200mm Lens
Very soft focus on D200
Hi.
I'm having trouble getting sharp images on my D200. I have a Nikkor 24-85 mm lens as well as a Nikkor 28-80mm. The focus is better when used with the 28-80mm lens. I use the exact same lenses on my D100 and the images are very sharp compared to the D200. I also get that I'll be focused on something but when I checkt the picture the focus shifted to the background.
Could you possibly assist me in fixing this problem. Thanks you
  • 423 Answers
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Posted on Mar 02, 2009
At 300mm focal length at a distance of 200 yards away what F stop will give me edge to edge sharpness in my photos?
The edge-to-edge sharpness of your lens is a function of the optical design much more than f-stop. What I would be more concerned with is depth of field. The important consideration is what the closest and farthest point you want to be in focus. Here are some figures that might help. For a 300mm lens focused at 200 yards (600 feet), mathematical calculations yield the following (0.03 mm circle of confusion in all cases):
f/22
Near limit = 256' 3", far limit = infinity, total depth = infinity, hyperfocal distance = 447' 5"
F/16
Near limit = 303' 9", far limit = 24,350' 8", total depth = 24,046' 11", hyperfocal distance = 615' 2"
f/11
Near limit = 359' 2", far limit = 1,821' 3", total depth = 1,462' 1", hyperfocal distance = 894' 9"
f/8
Near limit = 403' 4", far limit = 1,172' 2", total depth = 767' 10", hyperfocal distance = 1,230' 4"
f/5.6
Near limit = 447' 4", far limit = 910' 12", total depth = 463' 8", hyperfocal distance = 1,757' 7"
Jan 22, 2015 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Nikon 18-55mm lens will no longer zoom to 55mm.
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Feb 06, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Hello sir, Well it has been raining for a few days here and my cam has been exposedto bit of moisture as i indulged in a bit of early morning shoots. The thing is i get absolutely fantastic images with my...
It could be condensation inside the lens. It could be a problem with the focusing. It could be other mechanical/optical problems with the Sigma lens. If the problem persists after the lens has thoroughly dried out, take it in to a reputable camera shop and have it checked out by a qualified technician.
Aug 04, 2010 | Nikon D90 Digital Camera with 18-105mm...
Focus On My Subject
Change your metering mode to spot metering. Focus on your subject with half-press of shutter button...hold that press while you re-compose the picture and press the rest of the way. See if you get better results.
Apr 07, 2010 | Nikon D200 Body Only Digital Camera
Using a Nikon D200 with a new 18-200mm lens. When
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI,FIRST READ YOUR LENS SPECIFICATION CAREFULLY IT SAYS 18-200/3.5-5.6 IT SHOULD BE READ AS AT 18 MM IT IS F3.5,THEN AT 200 MM IT WILL BE F5.6 THATS WHY IT MOVES APERTURE FROM 3.5 TO 5.6.IT IS QUITE NORMAL. REPLY ME IF YOU ARE SATISFIED WITH MY EXPLANATION.
Jul 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D200 images not sharp
Your camera settings may be off. The D200 is very flexible when it comes to personalizing your settings, but they can be hard to navigate.
Try resetting using the built in reset feature. This will not affect your personal settings but may clear any unwanted changes. To do this, find the "QUAL and +/- " buttons on the top of the camera. Hold them both down for a few seconds. The top LCD blinks then the camera is reset.
This resets things like resolution, White balance and ISO settings.
Next, try setting your metering matrix to the middle position. Not the top and certainly not the bottom postion. This switch is located on the right side of the view finder.
If your lens has a "M/A - M", use the M/A setting.
There are three settings for focus. C, S, and M, located on the front of the camera next to the lens. Set your camera focus to "S". This will set it up for still subjects and prevent the sensors from tracking things that move. Also set on the AF area mode switch on the back of the D200.
Try these settings. If your images are still out of focus, you may have other issues that may require servicing by an authorized Nikon facility.
Apr 13, 2009 | Nikon D200 Digital Camera
Trouble with auto focus nikon auto nikkor 60 mm f2.8D
Lock it at f/32. Autofocus lenses have a lock for smallest aperture (highest number) because that is wht the camera body expects. The lock won't engage at any other position.
Feb 15, 2009 | Nikon Telephoto AF Micro Nikkor 60mm...
Nikon D40x AF-S Nikkor 18-55 mm 1:3.5-5.6 GII ED Lense Trouble
I've found the same thing with my D40x and the 18-55mm AF-S lens. I took a really close look at it and found that the mount on the lens is badly worn on all three of the bayonet tangs and one is cracked at the base. What happens in my case is that the lens has movement when mounted on the camera - just enough to stop the contacts from mating properly. Hence, no photos. Am taking it to Nikon to get it fixed. I suggest if this is your problem, that you take it to the repair man.
Apr 14, 2008 | Cameras
REPAIR
OK guys, it seems to be the lenses motor which for some reason burns out. I put a Nikkor 50mm 1.4 mm AF(great lens by the way) on the d200 body and it works fine. I sent the 18-200 in for repair and I won't tell you how much they wanted to charge me to fix it, thank God it's still under warrantee. Suggest you all try out another AF lens on the D200 body to see how that works. If ok then send in your boom lens and pray that your not over the 1 year warrantee limit.
Nov 01, 2007 | Kodak EasyShare C875 Digital Camera
Nikon D200 Digital Camera with 18-200mm Lens Logo
614 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
