Question about Brother MFC 240C All-In-One InkJet Printer
Where do i refill the yellow in on the Brother MFC-240c
Split the case then drill hole in the plug, fill with 15 cc of ink then screw in a set screw into hole to cap it off.
Posted on Mar 08, 2009
  • 544 Answers
Thank you for choosing Fixya.com.
please open the cover of your printer.
check the cartridges.
their you can see your ink instructing the color coding where it should be placed.
always be careful.
please don't forget to rate our answers properly
Posted on Mar 02, 2009
4 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Over-ride out of ink message Brother MFC-240C
Yes, you can cut a small piece of electrical tape and place it over the window on the inside edge of the cartridge. it has to wrap around the window tightly.
Posted on Jul 09, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
  • 265 Answers
SOURCE: paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Posted on Dec 12, 2009
How i refill ink in the printer mfc240c?the printer is from brother
If you refill the cartridge you broken the print head (clogged),and need to change.Do not refill the cartridge!!!!I'm a technician brother :)
Mar 09, 2011 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Mfc 240c will not print using black ink... cleaned and reinstalled ink cartridge that is full, but has been refilled. Any chance this is an easy fix issue?
we can refill 100 times but it woks.probly refiling methood is mistake. one time pul out all ink and gas of cartage by sering.and reffil again.
Oct 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c
The digital display on the printer will tell you which color is low and when it needs to be replaced, either black, magenta, cyan, or yellow.
Oct 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a Brother MFC-240C printer and need to refill my yellow ink cartridge but don't know how to. I have misplaced the instructions that came with the refillable ink bottles. Can anyone help me.
YOU are NOT SUPPOSED to "refill" the actual ink cartridges, but replace them with new ones. If you need to know how to replace this ink cartridge (I have this machine too) you just pop open the front rigth side panel and then pull the little plastic purple lever down in front of the YELLOW cartrdige which is labeled with a Y on the pull down cover in front of it, and pull out the old one to dispose of it, take the cap off the new one and push it in-the direction the arrow on the cartridge is facing until it clicks and the purple plastic piece locks it in, then shut the cover and the machine will do a "cleaning" and then you will be ready to print.
Feb 22, 2009 | Brother MFC-3240C All-In-One InkJet...
Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Refilling printer cartridge
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
use google translation from german language
May 13, 2008 | Brother Multi-Function Center MFC-240C...
Magenta Color Doesn't Print
refill ink cart can be problem here, print head may be blocked , try cleaning the head in warm water
Feb 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
113 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
