Question about Casio FX-300MS Calculator
How To Calulate??.
Formula:
Log10(P)=A-(B/T)-C Log10(T)+DT+E(F-T)/FT*Log10(F-T)
Here A,B,C,D,E,F are all Constant Values. And I am having the value of P. Now I Need To Find Out The Value Of T. How To Solve This Problem and Can i get One Summerized Formula for to calulate the T.
  • Casio Master
  • 7,993 Answers
If you are comfortable manipulating such an expression, I suspect your are also very able to scour the research litterature to find out if the unsung hero who has found a way to express the pressure in some non ideal fluid with 6 virial coefficients, has also provided a short and sweet way to solve for the temperature. (My guess).
To lift any ambiguity in the expression use extra parentheses in your last term:where does the denominator stop?
My suggestion is that you write a program to solve numerically for T or use some powerful software like Mathematica to obtain an analytical solution.
Good luck.
Posted on Sep 25, 2009
How to calculate volume
Each solid with a regular shape has a formula by which its volume is calculated. Once you know the formula to use and the values of the dimensions, just enter it in the calculator as it appears on paper (almost) and press enter/EXE/=
Make sure that the values of sides, radii, heights that are involved in formula must be expressed in the same unit.
The resulting value of the volume has unit
Unit_volume= (Unit of length used)^3
Nov 21, 2013 | Office Equipment & Supplies
What is the formula to calulate refrigerant r134 a from temperature to pressure
look up refrigerant pressure/temp chart
It should also be on any set of gauges your using for work with refrigerant
Jul 01, 2013 | Interdynamics RLS-134: Refrigerant R-134a...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Log10 Psat = A + B/T + C log10 T + DT = E ( (F-T)/T) log10 (F-T) A = 4.325629 E+1 B = -4.293056 E+3 C = -1.306883 E+1 D = 4.231114 E-3 E = 2.342564 E-1 F = 6.770000E+2
Hi
Log is a statement of current conditions
Psat is saturated pressure
T is temperature
DT is temperature difference
Regards
Gordon
Apr 20, 2011 | Heating & Cooling
I am trying to use the base of logarithm
Use the equivalent formula log base b of a is equal to [log10(a)]/[log10(b)], you can also use ln(a)/ln(b), the results will always be equivalent
Mar 13, 2011 | Sharp EL-531VB Calculator
MS Excel-Values in the formula in place of cell reference
Copy the cell(s) and then right click on the cell(s). Choose Paste Special and then choose Value. That will convert it.
Jun 22, 2009 | Microsoft Excel for PC
Excel 2003: Help with LOG formula
You've got some parenthesis in the wrong place. Try this:
=(86.01*(Log10(B2-B3)))-(70.041*(Log10(B4)))+36.76
Apr 06, 2009 | Microsoft Office Excel 2003 for PC
Excel will not displaying the results of a trend array formula
Hi Griffnz,
Your "known Y's" or 'values' are in Column B. This is the first array in the Trend formula.
Your "known X's" or 'months' are in Column A. This is the second array in the trend formula.
The trend formula is supposed to give you a projection of what the rest of the values in Column B will be over the next few months (usually continuing cells in Column A). The cells you want these values to show up in represent the third array in the formula.
Thus, your formula should look more like: '=trend(B3:B14,A3:A14,A15:A18)'
However, your formula is leaving out The values in B and adding values from C - -- but there ARE no values in C. Apparently, C is where you want the values to appear. In that case, the C array would be the third array in your formula. This would look more like '=trend(B3:B14,A3:A14,C3:C14)
If this doesn't make sense, let me know.
Sep 30, 2008 | Microsoft Excel for PC
Exel 2003
You can refer to cells that are on other worksheets by perpending the name of the worksheet followed by an exclamation point (!) to the cell reference. In the following example, the AVERAGE worksheet function calculates the average value for the range C1:C10 on the worksheet named Marketing in the same workbook.
default.aspx?assetid=za010939481033 Refers to the worksheet named Marketing default.aspx?assetid=za010939491033 Refers to the range of cells between C1 and C10, inclusively
  1. Click the cell in which you want to enter the formula.
  2. In the formula bar (formula bar: A bar at the top of the Excel window that you use to enter or edit values or formulas in cells or charts. Displays the constant value or formula stored in the active cell.) default.aspx?assetid=za060515351033, type = (equal sign).
  3. Click the tab for the worksheet to be referenced.
  4. Select the cell or range of cells to be referenced.
Jan 01, 2008 | Microsoft Office Standard for PC
Casio FX-300MS Calculator Logo
266 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
