Question about iLO (2 GB) MP3 Player
My pendrive 16gb transcend write protected ! i could not format also and I have tried above that registry value to 0. then also i could not !please suggest me
  • Anonymous Apr 08, 2009
    16 gb transcend pen drive not able to format
  • 81 Answers
Generally the pendrive above 8gb are slow and may not work some time better try to buy an external harddisk
Posted on Mar 02, 2009
My pendrive is write protect
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB memory card to your computer.
Nov 18, 2013 | Transcend (589307) Media
Sir good after. I have 4GB transcend 2.0 pendrive while copy some thing to penrive this drive a message is comming like " this disk can not be written to bacause it is trite protected please remove...
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
Mar 20, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pendrive is write protected please give me
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please click Start..Click Run...Type diskmgmt.msc and click OK
In the Disk Managemnet window that opens.Right Click on the pendrive and select Format.
In the window that pops up...set the file system nto NTFS and allocation size to default.
Please ensure that the 2 entries below with the checkboxes are not checked and click OK.
Now check if you are able to use the pendrive or not
in case not try the below steps
Click Start...Click Run.. Type Regedit and clcik ok.
In the registry editor window that opens ...navigate to the below path
Find the entry for Storage device policies
In case you are able to find it ...right click on it and click new and then Dword value.
Set the value to 0.
In case you were unable to find the Storage device policies entry...right click on the control entry and then click New and then Key. Name the Key as Write protect and then click ok
Now right clcik on Write protect and clcik new and then Dword value.
Set the value to 0.
Once done click Ok and close the registry editor window.
Restart the computer once for the change to take effect.
The above should be able to fix the issue.
In case not, Please let me know so that i can assist you further.
Nov 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have Transcend 2GB Pendrive. I didn't format the pen drive. If I click the format option, it will show the error message of below. Windows cannot format drive. quit any disk utilities or other programs...
Error message “Remove the write-protection or use another disk”. It won’t also allow you to format!
•Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
•Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies•Double click the key WriteProtect in the right pane and set the value to 0
•In the Value Data Box and press OK button
That is it, done.
Hope it helps
Aug 13, 2010 | Computers & Internet
USB drive write protected ????
There is a small unlock tab. Please push it in right place to unlock
Jan 26, 2010 | Transcend (589307) Media
WRITE PROTECTION PROBLEM
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6)run the mformat utility and select full format after full format yourwrite protection will be removed. try twice or thrice if you can'tcorrect at first time.
Thats all...
It worked for me and my friends....
Sep 10, 2009 | Transcend (589307) Media
My pen drive write protect problem
Try to format in windows vista .or in windows 7
Jul 04, 2009 | iLO (2 GB) MP3 Player
Write protected
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
May 23, 2009 | iLO (2 GB) MP3 Player
Displaying write protected while loading and deleting files
Dec 11, 2008 | Transcend (589307) Media
Problem regarding the write protection of pendrive
sir,
i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format, a window pops up saying that ur pendrive is write protected
Sep 03, 2007 | Computers & Internet
iLO (2 GB) MP3 Player Logo
365 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
