Question about SanDisk Sansa Fuze MP3 Player
My SanDisk Sansa Fuze Won't Charge Anymore
Basically what happens was i left the battery die all the way and i went 2 go charge it, it doesn't charge at all. What do i do?
  • 4 Answers
I had the same problem but solved it by connecting the apparently dead Fuze to a power charger for better than a week. Then I held the on/off button for 20+ seconds to do a reset and it came back alive and started acting normally including taking a charge from either the wall power or USB
Posted on Jun 11, 2013
Use a home charger not the USB charger. It is too weak to recharge the FUZE.
Posted on Mar 03, 2009
2004 Nissan Altima 3.5L BATTERY LIGHT went on during 15 minute drive. Next day car "died" while idling after a 20 minute drive. BRAKE WARNING LIGHT & BATTERY LIGHT on prior to full electrical failure.
Start with checking the alternator voltage with a multimeter. With the car off check the voltage in the battery which should be holding 12v charged less if flat of course then start the car and test the battery again. If the alternator is good you should be getting a reading of 14 to 14.5 v if it's the alternator it'll A) not put any charge into the battery or B) be a very low voltage being anything under 13.5 v
Sep 30, 2016 | 2004 Nissan Altima
MY CORDLESS PHONE BATTERY KEEPS DYING
You could try leaving it on charge a bit longer but if it keeps happening it either means dock doesn't charge the battery any longer (check for the charging symbol on the phone when in dock), or the battery in the phone has had its days.
Jun 05, 2012 | Vtech ia5870 Analog Cordless Phone
My battery light came on then my power steering went out. any ideas on what the problem is or how to fix it?
When the battery dies and the engine shuts down, the power steering will stop working. I would have the battery tested first, if the battery tests ok, then the cause may be the alternator is not charging the battery causing the vehicle to run on what charge is left in the battery till it dies. I would have both of those checked out by your local Auto Zone, or local Auto parts store, usually they will do this free of charge.
Hope this helps...
Sep 17, 2011 | 2001 Ford Escort ZX2
I have a 97 Sable and battery light came on and everything started going wacky. Lost all guages, speedometer, RPMs, etc. All lights came on my dash. Then all my lights went out and the car died. I was told...
that's becasue the new abattery went dead because it was not charging. The battery light must be OFF to charge the battery. Take it back to whoever fixed it. May be a bad wire betwen battery & alternator too.
check the 175 amp mega fuse in the engine compartment.
cehck this ground for a good connection - G104
Left front fender near air cleaner
check the 20 amp fuse for the charging system. Fuse 26 in teh engine compartment fuse box.
Aug 16, 2011 | 1997 Mercury Sable
My battery keeps going flat overnight. well i should say over a period longer than 8 hours left off. and it dies with in 5 minutes if i play my head unit or have the heater on with out the car on. and no i...
You answered your own question
You going in the right direction,but you don't
have the experience or meter to test anything
So you go to a repair shop & have the battery
tested ,as well as the alternator & current draw
Jul 18, 2011 | Ford Laser Cars & Trucks
Just shut off the care returned 2 hours later no go got a boost went for a drive left the car running for awhile than it start to get like it was going to stall went on g=for a littlwe while than died....
Hi your problem sounds like the battery is gone and won`t take a charge. When your engine is running the alternator is supplying the electrical power to run the car ( and normally charging the
battery as well )
Even though it seems strange for the battery to go suddenly, it does happen.
How old is the bat. Most last about 5 years with normal driving ( batterys last longer if the car is used every day )
Anyway i hope i have been of some help to you.
John (south Wales UK )
Jul 05, 2011 | 1995 Honda Civic
My battery keeps dying within 3 hours of taking it of the charger
Hello
I've found using the internet even briefly KILLS your batterys, especially if you do anything that requires streaming data (ie, youtube, streaming radio).
For instance, I listened to SomaFM streaming radio for about 10-15 minutes the other day (without headphones), and the battery went down 10% in that amount of time. You're basically talking 1% per minute when streamin audio. All I know is once this thing becomes a little more capable with streaming, I'm going to need to get a spare battery or bring my charger to work and just keep it plugged in.
Even worse is watching Youtube. I had a bit of downtime at work and watched 3-4 Bill Maher clips on youtube (this time with headphones). Over a period of 20-30 minutes, my battery went from 85-95% to 25%. It basically kills your battery, so be carefuly with youtube.
When I use my call normally for texts, emails, and calls it seems to hold a charge no problem. Especially when I consider that my brand new FULLY-charged laptop only lasts about 2 hours when
I'm using it for browsing the web.
You could also try disabling Pocketday.
THANK YOU FOR VISITING FIXYA
Jan 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
Apr 29, 2009 | Samsung SGH-a737 Cellular Phone
SanDisk Sansa Fuze MP3 Player Logo
372 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
