Question about Pentax ME Super 35mm SLR Camera
Loading/ Unloading the Film
When I was coming to the end of my film, out of the blue the film rewind knobdid not move when i pushed the rapid wind lever. And the sound it made indicated that the film is not winding either although I'm sure it had worked perfectly fine before. And when I unloaded the film by turning the film rewind crank, the rewind indicator did not flicker as it's suppose to. Please tell me that I didn't lose any of my pictures, it'll be a while before i get it developed, and why is it doing that? (it had happened before)
    Scholar:
  • 185 Answers
Anniehongx,
open the film door and charge the shutter. are the drive and take up sprockets turning? if they are then the film was not loaded properly. be sure to push enough film leader into the take up spool bars.
if the spools are not turning then a gear or spring ( advance lever return lock ) is broken.
there are no new parts for the ME Super however some camera repair shops have good used parts that can be used. get an estimate first.
Posted on Mar 02, 2009
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
I am having trouble unloading my holga 135mm. I finished taking pictures on my roll, and now when rewinding it so that all the film is back in it it just won't do it. Before this happened, when ever I...
This probably means that the film did not wind on to the take-up spool, so no photos were recorded. Check the results when you process it - if its completely blank, that is what has happened.
Aug 11, 2017 | Holga 135BC Film Camera
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me...
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
Oct 18, 2010 | Nikon FE 35mm SLR Camera
Cant wind up film!?
You haven't stated whether you activated the rewind knob before trying to rewind the film. Unless you do so, the rewind crank will not work.
The rewind knob is to the left of the lens mount (as viewed from the front of the camera), above the self timer lever and is marked with a letter "R". Turn it until the bar is horizontal and you should then be able to rewind.
if this has fixed your problem then please take a moment to rate my answer. If it has not done so, then please add a comment instead and I'll come back with additional options for you when I'm next online.
Jul 20, 2010 | Olympus Om1 Om1 Service Parts User Manuals...
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
Oct 30, 2009 | Minolta X-370S 35mm SLR Camera
New roll of film rewinds instead of advancing
Your camera has a faulty winding mechanism. It suppose to rewind in the end of the film when there are tension present but somehow the detecting system in your winding mechanism is detecting when the back door is closed. Remedy is replacing the clutch system within winding mechanism. Average repair runs about $90. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 21, 2009 | Nikon N55 35mm SLR Camera
My Pentax me Super won't load the film, why?
You must push the film leader in between the pins.
Some find it easier if they push the leader in first, and then draw the film cassette across the back and drop in into the cassete chamber. (Obvioulsy the rewind shaft remains withdrawn while you do this.)
If you press the film back lightly over the sprockets you can be sure they are propery engaged while you do this. Once the casette is in position you can push the rewind knob in. (A quick twiddle will ensure that the crank dog engages.) At this point you can operate the winder crank partially to ensure the film is properly engaged with the take up shaft before closing the back. Then proceed as per the manaul.
This sounds a bit more compicated then the instructions in the manual, but Pentax operatiin manuals have a reputation for obscurity!
One advantage of doing it this way is that you only use as much header as absolutey necesary. A lot of films have quite generous headers and this will get an extra frame or two out of the roll.
Also when rewinding, stop rewinding as soon as the header disengages. This leaves the film 'tail out'.
This is useful in two ways;
First it is easier to remove the film for processing. Often a device called a 'film picker' has to be used to pull the header back-out. This can scratch the first three or four inches of film, which might lose the first frame taken. Also if it does not succeed, the film cassette may beed to be broken open, which also risks scratching.
Second, the slot that the film emerges from may not always be light tight. Leaving a bit of film in the slot helps keep the cassette light tight.
(Note some types of special film use a backing which is unsually clear. These should not be left tail out, as the backing might conduct more light into the cassette. These are unusual films, (In fact I only know of one film where this is true!) so you will know if you are using one, and the instructions will make a big point about special loading an unloading precautions. So leave the tail out unless the instruction for the film say otherwise!)
A tip here is to keep an eye on the film run indicator. (the window on the back showing the red/black stripes.) This pattern moves from side when the film is fully engaged. It is operated by the upper section of the wind shaft. (Above the white pins.) This is turned by the top edge of the film, to when the tail of the fim header only is engaged it does not move. (Confirm this by rolling the upper end of the take-up shaft with the tip of your finger. You will see the run indicator waggle.)
This is intended to confirm that the film is properly engaged, you can't go by the frame counter. (On other cameras I have carried on shooting unaware that the film was not engaged, until the counter had shown 36 frames for five shots. You lose some good pictures that way!)
When rewinding this will stop moving as soon as the 'tail' is reached, telling you that the useful part of the film has been wound back. Another turn on the rewind crank will draw the first part of the film back into the cassette and you can then open the back.
Another handy tip is to crease the end of the tail over when you remove the cassette. This marks the film as exposed, and incidentally makes it impossible to wind the tail in my mistake.
Gordon
Alchemic Photography
PS: About pentax user manual in general.....
I think they were translated from Japanese by somone who's first language was neither Japanese nor English as a first language, after being written by somone whose main job was not technical writing, and then checked for grammar by an english language expert who's skill-set did not include photography.
This is a common problem. Often the cause is due to the 'spare man' effect. Ie the factory owner asks his factory manager who the best person to describe how to use the product for the manual writer. The factory manager, (who has production targets as his primary goal) then asks himself who he can spare from production work, and recommends the least productive dope on his staff. This is the 'spare man'. The manaul then gets written based on the opinions of the biggest dope in the fatory!
Even the latest manuals for their digitals are written this way. So in case anyone who has got a Pentax DSLR, the answer to the most common question is... "Yes you can use Pentax M series lenses on your camera. Just select the option to allow it in the menu.". (The manual says you can't at the beginning, and then when discussing th emenu options it tells you how to set the camera up to do just that. What is even more baffling is that once set it does not affect the use of any other lenses. In other words there is no reason for the menu option at all!)
Jan 23, 2009 | Pentax ME Super 35mm SLR Camera
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
Dec 15, 2008 | Pentax IQZoom 928 35mm Point and Shoot...
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
278 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
