Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Wiring problem
I have a k1152 ao smith motor i poled the wiring to make a repair and not shure where they go bac on do u have any diagrams that might help me
    Scholar:
  • 104 Answers
There should be a diageram under the cover that covers the wires,
Or note the two terminals marked L1 & L2. These are for the 2 power source wires from the circuit breakers. The ground is a seperate terminal.
You should not be servicing this type of equipment if you do not know the answer to your question,
Good Luck and make sure this motor is GROUNDED
Posted on Mar 19, 2009
Wiring diagram AO Smith ST1102 pump motor
There is almost always the wiring diagram on the outside of every spa motor.
Bath Spa Parts Online
Jul 24, 2016 | AO Smith Pool & Spa
Wiring issue
Without model info, try this link. Most motor brands follow pretty standard wiring setups. Please rate me if this helps.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Apr 16, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
247 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
