Question about Canon imageRUNNER 5570 Copier
ERROR i can getting one Error message,:THE DEFAULT KEY IS INVALID OR ITS CUREPTED"wat is default key
  • 59 Answers
This is the key you need to authenticate with windows servers etc. If you're not doing any emailing, sendig to folders etc the message won't matter but here goes how to sort it.
Press additional functions(star head) system settings, look for certificate settings (could be down one or two screens). Choose create key, call it a name, choose 1024 bit and a start and finish date. press generate key and wait a minute.
Press key list and make your new key the default. then highlight the default key and press delete. next press done or ok out to the copy screen, reboot the copier and everything should be ok.
Hopethis is ok if you need any further assistance let me know and I'll get back to you tomorrow when I'm near the machine, as I'm doing this from memory.
Posted on Mar 23, 2009
2 Suggested Answers
  • 113 Answers
SOURCE: i can getting one Error message,:THE DEFAULT KEY IS INVALID OR IT
ERROR “Default Key Is Corrupted Or Invalid”-----
ISSUE:
On the lower part of the Control Panel LCD display the message “Default Key Is Corrupt Or Invalid” appears.
RESOLUTION:
To eliminate this message from the machine display, follow these steps:
1. Go to ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS>CERTIFICATE SETTINGS>
2. Generate Key
3. Key Name: Input CANON
4. Select 1024 as the key length
5. Input the current date as the start date
6. Input an end date with current month and date settings but with the year listed as 2025
7. Start Key Generation
8. Go to Certificate Settings and select Key and Certificate List
9. Highlight Default Key and press Erase
10. Exit out of System Settings and Additional Functions.
11. Cycle Main Power of copier.
Good Luck!!!
neo
Posted on Mar 02, 2009
Ms office 2007 product key
either your ms office is not genuine or u need to reinstall it.it is bettere to reinstall it..
Dec 24, 2012 | Microsoft Office Professional 2007 Full...
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
I am getting an error " Default key corrupt or
you go in system setting and go for network setting option and make the setting key off. this message will go off.
Jul 18, 2011 | Canon ImageRunner C-3170I Copier
Hi friend my nokia N70 is hang problem wat i say make a one phone call just hanging and then no response wat can i do plz help me
Try to reset:
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 21, 2010 | Nokia N70 Cellular Phone
Error accessing valid language directory
I got the invalid language error recently rescuing a copy of CADKEY 19 from an old WIndows 2k server for an engineer where I work.
I eventually was able to get rid of the error message by searching for the string CK19 in regedit and altering keys with invalid paths to them from the previous install.
CADKEY 19 seems to store a lot of static paths in the Windows registry, I had to update at least a dozen or so.
Using the Find Next feature with regedit made finding the keys and updating them purty easy.
Dec 10, 2010 | Cadkey Corp CADKEY Version 6
Hey wen i insert a sim card it gives error of invalid simcard. now wat to do???
You need to unlock your mobile to use different network in your mobile. When you unlock it to the current network you will not get the "invalid simcard"error. You can unlock your mobile at www.mobile-unlocker.com quickly.
Oct 05, 2010 | Nokia E71 Smartphone
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Error accessing invalid language directory when opening cadkey
Apr 08, 2010 | Cadkey Corp CADKEY Version 6
Dose anyone no wat thease codes codes meen as my car wont start but turning the key on an of a few times it brings up thease codes p1130 and p1685
P1130 - HO2S Circuit Low Variance Bank 1 Sensor 1
P1685 - Skim Invalid Key - The engine controller has received an invalid key from the SKIM.
CLICK HERE for a full list of OBD Codes for the PT Cruiser.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 05, 2009 | 2004 Chrysler PT Cruiser
Canon imageRUNNER 5570 Copier Logo
141 people viewed this question
old marine
old marine
