Question about Canon imageRUNNER 5570 Copier
I can getting one Error message,:THE DEFAULT KEY IS INVALID OR ITS CUREPTED"wat is default key
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
ERROR “Default Key Is Corrupted Or Invalid”-----
ISSUE:
On the lower part of the Control Panel LCD display the message “Default Key Is Corrupt Or Invalid” appears.
RESOLUTION:
To eliminate this message from the machine display, follow these steps:
1. Go to ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS>CERTIFICATE SETTINGS>
2. Generate Key
3. Key Name: Input CANON
4. Select 1024 as the key length
5. Input the current date as the start date
6. Input an end date with current month and date settings but with the year listed as 2025
7. Start Key Generation
8. Go to Certificate Settings and select Key and Certificate List
9. Highlight Default Key and press Erase
10. Exit out of System Settings and Additional Functions.
11. Cycle Main Power of copier.
Good Luck!!!
neo
Posted on Mar 02, 2009
2 Suggested Answers
  • 59 Answers
SOURCE: ERROR
This is the key you need to authenticate with windows servers etc. If you're not doing any emailing, sendig to folders etc the message won't matter but here goes how to sort it.
Press additional functions(star head) system settings, look for certificate settings (could be down one or two screens). Choose create key, call it a name, choose 1024 bit and a start and finish date. press generate key and wait a minute.
Press key list and make your new key the default. then highlight the default key and press delete. next press done or ok out to the copy screen, reboot the copier and everything should be ok.
Hopethis is ok if you need any further assistance let me know and I'll get back to you tomorrow when I'm near the machine, as I'm doing this from memory.
Posted on Mar 23, 2009
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
I am getting an error " Default key corrupt or
you go in system setting and go for network setting option and make the setting key off. this message will go off.
Jul 18, 2011 | Canon ImageRunner C-3170I Copier
My nokia n73 is very slow. i want to format it's phone memory. when i press code it ask for lockcode..i gave 12345 and 00000 but it didn't accept....wat should i do?? plz help
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone
1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number '3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Formatting' to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Jan 24, 2011 | Nokia N73 Cellular Phone
Hi friend my nokia N70 is hang problem wat i say make a one phone call just hanging and then no response wat can i do plz help me
Try to reset:
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
2. Now Press following key-*#7370#
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Dec 21, 2010 | Nokia N70 Cellular Phone
My phone is showing an error message "3d010017"
hi , To fix the error , please reinitialize the software of ur mobile . i will give u the step
    1. While in standby mode, press the left soft key for Menu
    2. Select Settings (9)
    3. Select Reset Settings (8)
    4. Press the OK button to check the box(es) for the following:
      • All: Phone, Display, and Sound settings will be reset to the default values
      • Phone settings: Only the Phone settings will be reset to the default values
      • Display settings: Only the Display settings will be reset to the default values
      • Sound settings: Only the Sound settings will be reset to the default values
    5. Press the left soft key for Reset
    6. Press the left soft key for Yes to reset the handset
    7. Enter the password, using the keypad, default password is "00000000"
    8. Press the left soft key for OK to reset the handset
    For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 15, 2010 | Samsung SGH-t219 Cellular Phone
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Stuck key. No opening of Windows
ok hit the f1 key inter the bios and in bios look to the bottom of the screen or upper left corner . you will see load default. ok load the default then save and exit.
Nov 12, 2009 | IBM ThinkPad R50e Notebook
ERROR
Mar 02, 2009 | Canon imageRUNNER 5570 Copier
Product Key Code on Windows sticker located on back of hard drive
If you are admant that the purchase code and install codes match then follow the onscreen failure notification until you get to the "call our support desk on" Etc....
If you try to install Windows XP Service Pack 1 (SP1) or Windows XP Service Pack 2 (SP2), you may receive the following error message: The Product Key used to install Windows is invalid. Please contact your system administrator or retailer immediately to obtain a valid Product Key. You may also contact Microsoft Corporation's Anti-Piracy Team by emailing piracy@microsoft.com if you think you have purchased pirated Microsoft software. Please be assured that any personal information you send to the Microsoft Anti-Piracy Team will be kept in strict confidence
How to obtain a replacement product key loadTOCNode(3, 'moreinformation'); To replace a Microsoft product key, you must contact Microsoft Customer Service and Support. To locate the appropriate telephone number, visit the following Microsoft Web site:
http://support.microsoft.com/default.aspx?scid=fh;EN-US;CNTACTMS (http://support.microsoft.com/default.aspx?scid=fh;en-us;cntactms) Note When you contact Microsoft Customer Service and Support for a replacement product key, you may have to pay a fee. You may also have to provide information from your computer or from the product CD or DVD when you are speaking to the customer service representative.
Feb 07, 2009 | Microsoft Office Professional 2007 Full...
Canon imageRUNNER 5570 Copier Logo
4,719 people viewed this question
old marine
old marine
