Question about Sony ICF-SW7600 AM/FM/SW Radio
Sony ICF-7600D Radio side is dead
Clock section seems to work fine but with new batteries there is no life in any of the RF displays, nothing from the speaker.
I have a manual on the way from Australia but thought that since y'all have a big braintrust there might be something I can do while I wait for it.
Thanks in advance!
- Bill
  • tuftdmc Mar 15, 2009
    Hi
    I have the same fault the radio is dead except for the clock ,i tried fresh batteries but no joy,this is a very good radio when its working,rather try and get it fixed than throw it away.-------Any help appreciated,thanks.
    Regards Ian
  • Anonymous May 01, 2009
    My 7600 suddenly stoped receiving all AM throughout all frequencies,except for constant background QRN. Plays FM bands okay, though. Thishappened suddenly last night after radio had been sitting for a coupleof years (batteries out). It played okay for about 15 minutes, thennothing.
Getting ready to send it to ACT ELECTRONICS in US.
Posted on Mar 03, 2009
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
Buttons not working on Sony icf-cd7000
Hello
Unplug the unit and replug it after 5 minutes or so. Then Hold Down the CLOCK/DATE until a short beep sounds. If this beep sound cannot be heard, be sure that the internal circuit has some trouble, and has to be repaired. Normally, any other button get strucked, there will be no response with other buttons. OK.
Nov 02, 2011 | Sony ICF-CD7000 CD/MP3 Clock Radio (Black)
My ICF-7600D shuts off after a random time of use. The Timer function is not used. Happens with internal batteries or with external power supply. Computer batteries are OK. Thanks.
Not sure of the actual problem but try not to actuate the sleep function or the standby as this may cause the radio to turn off at intervals. I have the ICF2003, same thing.
Feb 07, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Need to purchase new telescopic aerial for Sony, here in the uk
May have to make one up from a different radio as SONY no longer makes this model. I can search for a parts house for you but you need to email me or get me your email.
Jan 02, 2010 | Sony Audio Players & Recorders
I have lost the AC Adaptor. I wish to buy a new one.
Manufacturer Sony Part Number 1-467-906-11 Description ADAPTOR, AC try go to Radioshack sorte or
http://www.radioshack.com/home/index.jsp
Oct 29, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-SW77 no Audio
you can get the service manual online at www.mods.dk
Jan 15, 2007 | Sony ICF-SW77 AM/FM/SW Radio
Sony ICF-SW7600 AM/FM/SW Radio Logo
492 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
