Question about Microsoft Windows Vista Ultimate Edition
Error [678] Problem-Error [678]:The remote computer did not respond.for further assistance click more info or search help and support center for this error number
  • Anonymous Mar 18, 2009
    "Error [678]
  • 564 Answers
Hi, Step 1: Make sure the network cable is connectedMake sure that the network cable is connected to the computer and to the modem. If your computer connects to a hub or to a router, make sure the cable that connects the hub or the router to the modem is connected. Step 2: Make sure that the network adapter is enabled
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click the Local Area Connection icon. Click Enable if the option is available.
Step 3: Reset the modem
  1. Disconnect the cable that goes from the computer to the modem.
  2. Turn off the modem. If the modem does not have a power switch, disconnect the power supply from the modem.
  3. Wait two minutes.
  4. Turn on the modem, and then connect the cable that goes from the computer to the modem.
Step 4: Uninstall and then reinstall the modem and the drivers by using Device Manager
Before you follow these steps, you may have to download the latest driver for your network adapter from the hardware manufacturer.
  1. Click Start, click Run, type sysdm.cpl, and then click OK.
  2. Click the Hardware tab, click Device Manager, and then locate Network Adapters.
  3. Expand Network Adapters, and then right-click the icon for your network adapter.
  4. Click Uninstall, and then click OK. In the dialog box that prompts you to remove the files that are associated with this device, click Yes.
  5. Restart the computer. Or, click Action, and then click Scan for hardware changes.
  6. If Windows finds the device but does not recognize it, you must install the latest driver for your network adapter.
If you have a Realtek 8139 network adapter, updating the driver seems to resolve this issue. For more information, visit the following Realtek Web site: http://www.realtek.com.tw/downloads/Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Step 5: Create a new DSL or cable connection
  2. Click Create a new connection under Network Tasks. Click Next when the wizard starts.
  3. Click Connect to the Internet, and then click Next.
  4. Click Set up my connection manually, and then click Next.
  5. Select Connect using a broadband connection that requires a user name and password, and then click Next.
  6. Follow the remaining steps. Use the connection information from your Internet service provider (ISP) to complete the wizard.
Note You may have to use software that is supplied by your ISP to create the new connection.
Posted on Mar 02, 2009
  • Prem  Kumar
    Prem Kumar Mar 02, 2009
    Step 6: Repair Winsock and TCP/IP
    1. Click Start, click Run, type netsh winsock reset, and then press ENTER.
    2. When the Command Prompt window flashes, restart the computer.
      Warning Programs that access or monitor the Internet, such as antivirus, firewall, or proxy clients, may be negatively affected when you run the netsh winsock resetcommand. If you have a program that no longer functions correctly after you use this resolution, reinstall the program to restore functionality.
    Step 7: Temporarily uninstall third-party firewalls
    Some third-party firewall software such as ZoneAlarm and Norton Personal Firewall may cause Internet connectivity issues on computers that are running Windows XP SP2. You may have to temporarily uninstall these programs to test the computer. Disabling these programs may not be sufficient for testing. Make sure that you have the CD or the installation files so that you can reinstall the programs later. If these programs are causing the problem, you may have to contact the program vendor if you need help with the settings for that program.
    Note You may want to verify that the Windows XP firewall is enabled before you remove the third-party firewall program.
    Step 8: Scan for and remove spyware and adware
    We recommend that you install Microsoft Windows Defender. To obtain Windows Defender or to obtain additional information about tools that you can use to remove unwanted software from your computer, visit the following Microsoft Web site:
    http://www.microsoft.com/protect/compute...
    Step 9: Clear the temporary Internet files
    1. Start Microsoft Internet Explorer.
    2. Click Tools, and then click Internet Options.
    3. On the General tab, click Delete Files.
    4. Click OK in the Delete Files dialog box, and then click OK.
    Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
    PREM
  • Prem  Kumar
    PREM
2 Suggested Answers
VenkY3K
  • 118 Answers
SOURCE: Error 678
Error 678 is with if you had given wrong username & Password., pl verify correct UN & pswd it must be very case sensitive is there any special character included in the UN & pswd., verify then try again., it will works....
Posted on Mar 30, 2009
What is error 678 in zte cdma device?
The error means:
see this answer:
https://uk.answers.yahoo.com/question/index?qid=20070527225936AARDAsv
Jun 11, 2014 | Toshiba Computers & Internet
A connection to the remote computer could not be established, so the port used for this connection was closed. For further assistance, click More Info or search Help and Support Center for this error...
Sounds like your trying to connect to a remote computer. Steps to take and things to check.
1. Make sure the remote computer is on. 2. Make sure the remote computer is connected to the internet 3. Make sure the remote computer does not have a firewall blocking the port connection.
Some applications use certain ports on a computer to send/recieve data. If the computer has a firewall, like windows firewall or Kaspersky Internet Security, that port or application could be blocked, and that could cause the problem.
4. Make sure your computer does not have that application or port blocked.
If you can get to say www.google.com on both computers, then steps 1 and 2 are done. Look to a firewall or security application next. Beyond that I will need more information.
Aug 19, 2011 | Computers & Internet
I have dell studio 15 lap top with windows 7 operating system. yesterday i bought tata photon plus data card. when am try to connect i am getting 678 error: remote computer did not respond. I have...
This error is due to modem not responding problem, or signal strength is low.To cure this error, Follow the below steps :-
Goto start program - control panel - click on phone and modems options - A Window named as Location information opens
Select the country/region are you in now - then specify the area code (or city code) are you in now - then select tone dialing - click on ok button Phone and modem options window will open with the details you have entered in previous window...
Thanks & Regards
Anas K A
May 17, 2011 | Computers & Internet
I am not able to connect to a broadband connection via my Dell Latitude D620 laptop. the error that it shows is Error 678 : remote computer didnt respond.
make sure ethernet card is in slot tight screw down go to computer ,system propertys, go to device manager, trouble shoot it.
Feb 17, 2011 | Dell Ethernet Card Network Adapter
I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Oct 09, 2010 | Computers & Internet
When I connect My MTS MBLAZE shows me an error message "The remote computer did not responde for further assistance" and do not respond when I check my balance and my phone number. When i check balance for...
When I connect My MTS MBLAZE shows me an error message "The remote computer did not responde for further assistance" and do not respond when I check my balance and my phone number. When i check balance for last time their is 4 MB(approx.)data usege remening. solve this problem please.
Jul 28, 2010 | Computers & Internet
Critical error 678 on mobilepro 790
error code is 678 means Ur com port not correct configure so before u connect anything u must to configure correct.
Mar 02, 2009 | NEC MobilePro 790 Pocket PC
Error 678: The remote computer did not respond.for further assistance click more info or search help and support center for this error number.
Mar 01, 2009 | Microsoft Windows Vista Ultimate Edition
I can't connnect to intrnet
SYMPTOMS loadTOCNode(1, 'symptoms'); When you try to establish a dial-up connection after you upgrade your computer to Microsoft Windows XP from Microsoft Windows 98, from Microsoft Windows 98 Second Edition, or from Microsoft Windows Millennium Edition (Me), you may receive an error message that is similar to one of the following: Error 721: The remote computer is not responding. Error 678: The remote computer failed to respond. Error 691: Access was denied because the user name and/or password was invalid on the domain. Error 777: The connection attempt failed because the modem or other connecting device on the remote computer is out of order. To resolve this issue, contact the hardware manufacturer to inquire about how to obtain and install the latest Windows XP-compatible driver for the modem or download an XP driver for the modem
Feb 14, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
447 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
