Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Problems when trying to refuel
Husqvarna 316. What should be in the hole at the top left hand side of fuel tank, just in front of plastic tank to carb fuel pipe, as when I try to refuel the petrol just flows out of the hole.
  • 257 Answers
Hi, The primer bulb is missing. They are easy to replace, they snap in and out and the fuel lines are on slip fittings. This should Fixya!
Posted on Mar 02, 2009
Husqvarna 235R Manual The fuel lines on my 235R disintegrated. I have cut new ones from the right sort of tubing but cannot figure out where to route them to prevent fouling other parts. Is this shown...
The fuel hose from the tank goes under the carb to the left hand side of the carb and in front of the two feet on the bottom of the air filter housing, it is all a bit tight under there, the right hand pipe goes from the carb to the shorter connection on the primer, a pipe from the longer connection on the primer goes back to the tank
Oct 09, 2013 | Garden
How do I replace fuel line on my Husqvarna 136/141 Chainsaw
This is not as easy as it sounds, this machine uses a micro bore hose which is an interference fit in the tank, to replace it you will need to remove the fuel tank from the saw, to do this start by removing the guide bar and chain, remove the three screws securing the top cover and remove, remove the two screws holding the air filer and remove, remove the two 10mm nuts hloding the filer back plate and remove, remove the two 7mm head boltssecuring the carb, remove the two cross head screws securing the metal bracket against the carb, lift the carb away with the throttle wire and choke pull attached, diss conect the fuel hose, now remove the four screws holding the starter cover on, two screws are self tapping and go into the plastic cranlcase the other two are machine screws and go into the anti vib mounts, when replacing make sure they go back in the same holes in the starter cover, on the other side of the saw remove the 4mm allen screw securing the chain catcher in the bottom r/h side of the saw, this also screws into an anti vibe mount, remove the cross head screw at the top l/h side of the saw and remove the orange plastic square cover, the fuel tank will now drop out of the bottom of the saw with the top handle still connected,pull the old fuel hose out through the the fuel filler hole with the filter still connected, ncut a point on one end of the new fuel hose and push down through the top of the tank, grab with a pair of long nose pliers through the filler hole and pull the hose in, trim the end and re fit the filter, allow enough hose to allow the filter to move around in the tank, re fit the tank and securing screws, re build in reverse of diss assembly.
Apr 12, 2013 | Husqvarna Garden
How do I replace fuel line on a husqvarna 142 chainsaw
Apr 05, 2013 | Garden
Need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Sep 09, 2012 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I HAVE A HUSQVARNA MONDO LINE TRIMMER.WHERE DO THE FUEL LINES CONNECT.THE MACHINE HAS A WALBRO CARB.
For a machine with a remote primer bulb: The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. For a machine with the purge/primer bulb on top of the carb: The small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Oct 25, 2010 | Husqvarna 28cc Gas Line Trimmer
Trying to take apart to replace fuel hose.taken screws out and lid offvaccum.but will not come apart why.jerry
Sometimes, its easy to miss a "hidden" screw. The plastic case probably has plastic guides for it they may even interlock together. Search again for a "hidden" screw before giving up. You will find more than just one fuel line. Here is how you would replace them if you choose to do so (recommended).
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Aug 19, 2010 | Poulan Pro Super Blowervacuum
Fuel pipes te610 husqvarna
the tank thumbscrew on the left side is you reserve. it needs to connect to the petcock on the right side, across the carb to the top pipe. the petcock should have arrows on it (backside). the bottom petcock pipe goes to the carb. the carbs inlet pipe is on the right side and is adjustable...single screw in the center of inlet pipe allowing it to be rotated for straighter hose connection. that is depending on year of coarse.
May 01, 2009 | 2000 Husqvarna TE 610
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
73 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
