Question about Microsoft Windows XP Professional
Msconfig how to know that this process
    Scholar:
  • 56 Answers
Plug the process name into one of these:
http://www.neuber.com/taskmanager/process/index.html
http://www.processlibrary.com/
Posted on Mar 02, 2009
My computer is taking a long time to shut down
push buttons at same time: Alt, Ctrl and Delete to bring up five item menu. Choose the last one "Start Task Manager".
Choose tab "Processes". Chose "show processes from all users. Click on CPU twice to order the processes from highest to lowest. System idle should be close to 99%. If there is a process that is taking up significant resources, then that is your problem.
Sep 10, 2013 | Microsoft Windows 7 Ultimate for PC
I have damaged my screen on my acer aspire 6920 laptop i plugged in a hdmi lead and was working on a separate monitor until i went into ms config and removed some processes from start up and now can only...
Please login to msconfig and select "enable all" on startup. It might be recovered. Try it. if not let me know the issue with some more details like what processes are present in startup .
Jun 14, 2011 | Acer Aspire 6920 Notebook PC
Why is my dell computer so slow?
Use CCleaner, Auslogic Disk Defrag, install Spyware Terminator and run full scan, remove programs from startup. You can also use "msconfig" (start/type it in, choose) to really lower the amount of processes and programs running but I wouldn't recommend unless you know what's vital plus check the box to remove all Windows processes from list before you start disabling processes.
Sep 02, 2010 | Dell Computers & Internet
How to unblock parent control
U got to login with administartor account
or simply go into safe mode
START>RUN>MSCONFIG
open up MSCONFIG
Disable all startup items and hide all microsoft process and disable all the processes click on apply and restart the system...it should work
Jul 17, 2010 | Microsoft Computers & Internet
Slow boot time for Windows XP Pro
You can do that by using "MSCONFIG"
Click 'start' then goto 'run' and type 'msconfig' then click 'Ok'
That will open the Microsoft System Configuration Utility. You can then disable the unnecessary services and apps
For more information, please refer
http://support.microsoft.com/kb/310353
Dec 18, 2009 | HP Compaq Business Notebook 6910p
Hello. My HP Pavillion dv4t continues freezing on me two to three times a day. It happens when I am doing almost anything on my laptop: internet, iTunes, BlackBerry, school. I cannot even move my mouse or...
use msconfig to disable unwanted processes that loads when you start windows.
1. press WINDOWS LOGO (in your kboard) + R
2. Run dialog box opens
3. type msconfig and press enter
4. click the startup tab and "DISABLE" the processes which you think unnecessary. just disable them dont delete them. just play trail and error
5. try also to disable services that are not needed in the Services Tab
cheers!
Aug 14, 2009 | HP Pavilion DV4T Notebook
Programes running in background
Press Ctrl, Alt and Del and click on the processes tab, this will show you what processes are running in your computer at the time.
If you want to stop certain processes from starting up with the computer then in the run box type msconfig, this will bring up the system configuration utility, click on the startup tab and you will see what starts up with the computer, in that tab you can disable or enable processes.
Be careful what you are doing as you can mess certain settings up if disable the wrong process.
Regards.
Jul 16, 2009 | IBM Computers & Internet
The same runtime prob....... pls help
You will have to go back into msconfig and recheck all the boxes again that you unchecked, restart the PC and use msconfig to uncheck 1 process at a time, then you will know what processes was killed.
Good luck.
Jun 30, 2009 | Microsoft Windows XP Professional
Xp windows explorer delay w/ "open with"
Sounds like you have too many background applications running that intercept right-clicks for their own functionality.
Click Start>Run and type in "msconfig". This runs the configuration utility that shows your startup programs and services. Select the "Diagnostic Startp" option , then click "Apply" and follow the restart instructions. When your system reboots select cancel when asked to restore the settings. Now all those burdensome background running applications that sap your system resources will be eliminated (temporarily) and Windows can run without being dragged down.
Try your issue again. If this time its quick and without the long lags you reported, you'll know that at least one of those startup applications is the culprit. Running msconfig again will allow you to restore the Normal Startup, and the Startup tab will allow you to remove selectively that application that is causing the issue.
One way to identify which one is the culprit is to restart normally (select the Normal Start option in msconfig and reboot) and once back up, do a ctrl-alt-del to bring up the Task Manager. Click the "Processes" tab and then click the heading "Mem Usage". This will sort running processes by how much memory resources they consume.
The memory hogs may not be the one giving you the problem, but it's likely that a heavy consumer is sapping the CPU cycles needed to handle your right-click pop-up menu and run-with selection. Make a note of the top heavy memory users (print a screenshot) and use this list to eliminate any that are also on the startup list back in msconfig.
Don't use the "End Process" button in the Task Manager to simply stop them, as you'll likely stop one that is critical to Windows functionality. Msconfig's Startup list just shows the ones that get started at Windows boot up and can be eliminated without crippling Windows - much safer.
Use your memory hog list to start eliminating, one at a time, the offending applications from the startup list until the issues is resolved. Its a little tedious, but helps clean up your system in the process.
Hope this helps.
Dec 27, 2008 | Microsoft Windows XP Home Edition
Error window appears that reads "Can't find resource file". This happens at every restart of Windows.
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Thanks
Jul 23, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
