Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
THE WIRES CAME OFF THE 4 TERMINALS ON MY MM875 LAWNMOWER. WHICH WIRE GOES WHERE?????? TERRY terbear7@cox.net
2 Suggested Answers
  • 313 Answers
SOURCE: need blade for black&decker lawnmower
part # 242381-00 black & decker
Posted on May 29, 2008
NEED HELP TO REPLACE WIRES ON CAPACITOR ON GE ROOM AIR CONDITIONER 8000 BTU
with capacitors it doesn't matter which wire goes on which terminal
if it has just 2 terminals then a wire on each
if it has 4 terminals then one wire on one set and the other wire on the other set
A set is two terminals side by side
However if you are still undecided , get an electrician to fit the wires.
May 09, 2015 | General Electric GE AEM08LQ 8000 BTU...
How to wire the capacitor on a a o smith motor bn37 115 volt 11 amp
The 4 terminals are actually only on 2 terminals!
If you look closer, you will see that 2 terminals are actually on SAME post. So...
place a wire into one spade terminal, and then Cross over diagonally with the other wire.
it does not matter which wire goes where. Just be diagonally across from each other.
Jan 20, 2015 | AO Smith Pool & Spa
I have to replace the power switch on my Delta Shopmaster 10" radial arm saw. I have the switch, which is a Delta 438010170206S Rocker Switch has (4) terminals. I need to know which wire goes where????
How many wires do you have? The switch is probably a 2 pole, On-Off. If you have 2 wires, connect them to two terminals on one side of the switch (use an ohm-meter to find which terminals make-break). If there are 4 wires, connect the black and white power cord wires to different sides of the switch. Then connect the two motor wires to the two remaining terminals. DO NOT CONNECT THE BLACK AND WHITE POWER WIRES TO THE MAKE-BREAK TERMINALS OF THE SWITCH. This creates a short in the power cord and will trip a breaker.
Oct 29, 2013 | Delta 10" Shopmaster Radial Arm Saw 1-1/2...
I need to exchange the electrical cord from a 4 conductor to a 3. Which of the 4 colors (red, black, white, green) are the ground wires and which are the hot wires?
Red&black are hot
white is neutral
green is ground
on the 3 wire cord
the outside wires go on the outside terminals on the connection block
the center wire goes on the center terminal
Sep 10, 2011 | Estate TEDX640JQ Electric Dryer
How do install a 4-wire dryer cord when there are only three terminals? Where do I put the ground(green) wire?
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
Aug 20, 2011 | Dryers
How to connect a 4 prom receptical
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 04, 2010 | GE DSKP233EWWH Electric Portable Dryer
Dryer cord
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
Switch diagram needed
Funny, I came here because I just opened up the switch case on my MM875. Hold the switch so the terminals are on top. Call the black switch (the part you push in to power up the mower) north. The north post gets white (metal connector). The west post gets red (plastic connector). The east post gets the black that comes from the mower's motor (plastic connector). The south post gets the black that comes from the outlet (metal connector)
(Black Plastic Switch)
White (Metal)
Red (Plastic) Black (Plastic--from motor))
Black (Metal--from outlet)
May 22, 2009 | Black & Decker 19" Electric Lawnhog...
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
217 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
