Hi sir...how to pass messages between the nodes in MANETS
Actually i create a one network with n number of nodes in MANET.But i want to pass messages between the nodes and pass the vote request message to all nodes in network,but i could not get this, can you help for this.please...........
  • 611 Answers
Dear sir make it in the access point mode and connect this to switch or modem or router then you get it
Posted on Mar 03, 2009
I am getting a u1153 code along with p0300 and B0092. How do I fix this? We have already replaced the ignition coils and spark plugs.
What make , model an year vehicle ? U1153 is a communication code . Vehicles with more then one control module have a serial data network for the control modules to talk to each other on . p0300 is a random misfire which could be low fuel pressure , vacuum leaks etc..
https://www.obd-codes.com/b0092
Vehicle doesn't start an run ?
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification (ID) number of the module which sent the message for state of health monitoring/node alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an ID number is learned by a module, it will monitor for that modules node alive message. Each module on the class 2 serial data circuit is required to send a Node Alive message every 2 seconds. When no message is detected from a learned ID number for 5 seconds,
your best bet , take it to a qualified repair shop .
May 24, 2017 | Cars & Trucks
07 Chevy express when blower motor is in operation with highest setting, ABS and parking brake light's come on with ringing tone Code U1041 showed up on obd scanner What is possible cause? Thanks
Sounds like a network communication issue.
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for state of health monitoring/node alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that modules node alive message. Each module on the class 2 serial data circuit is required to send a Node Alive message every 2 seconds . When no message is detected from a learned identification number for 5 seconds , a DTC U1???.
??? is equal to the 3 digit identification number of the module. Control Module ID = BCM
I would start checking ALL ground wires/straps on this vehicle. That has been a problem with GM. Try clearing the code and see if it comes back after you clean ground connections.
Dec 30, 2015 | Cars & Trucks
Downlaod tz180 firmware
You need to login to mysonicwall.com to download this firmware. Did you create an account at mysonicwall.com and register this SonicWALL in your account? If you haven't you will need your device serial number and activation code, both of which are printed on the back of your firewall.
Jan 20, 2014 | SonicWALL TZ 180 10 Node Firewall...
2002 Chevy Avalanche "U 1041" Loss of EBCM/EBTCM communication. Both front and rear rotors,brake pads and hardware has been replaced. But I found out they did not do the emergency brake. Also this shop did...
How did you come up with this code ? U 1041" Loss of EBCM/EBTCM ????? Do you what U code's are for ????? Brake pads an rotors have nothing to do with this code ! This is a problem with the serial data communication network or the ABS module it's self .
DTC U1001-U1254
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for state of health (SOH) monitoring/node alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that modules node alive message. Each module on the class 2 serial data circuit is required to send a node alive message every 2 seconds. When no message is detected from a learned identification number for 5 seconds, a DTC U100 000 is equal to the 3-digit identification number of the module.
your best bet ,chevy dealer !
Oct 15, 2017 | Cars & Trucks
Can i connect 2 a wireless network?
Actually it is an office with 2 different networks. Currently there are two wireless routers (router A connect to network A; and router B connect to network B), then router A with a server set for internet access. The two network somehow link together already, but all nodes in both networks can't see each other(cant share files thru "My Network Place"). All nodes equipe with Windows XP.
It’s help u.
And Thanks.
Mar 03, 2010 | HP 285527-001 - Compaq Presario...
Virus affected our network
hello sir,
first checkout which one node uploding more data on network, nd chocked ur whole network, remove these node from ur network and check another node working good then scan findouted pc from symantec antivirus otherwise take backup and reinstall windows on problumatic pc.
Yogesh Tetarwal
(System/Network Engineer)
Feb 02, 2009 | HP Compaq thin client t5510 (PC539TABU)...
Ear piece
hello sir,,,, passcode and pin code for first time u connect to any mobile have to be created.. it automatically create it ... when u connect it to device it will ask for create passcode.. then type any passcode u like(e.g 0000) while its being connecting press 2-3 time headset's vol key then it will connect....
Jun 21, 2008 | Motorola Mobility HS801 Consumer Headset
Sending message
pl check the messenger service is enable and running in both server as well as nods (win XP). Hope it will work.
Jun 19, 2008 | Microsoft Windows Server Standard 2003 for...
Send message
Greetings,
Are you using Windows Messenger ?
And what is the error / alert / info message ?
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
